VLAN Subnets
ccooper77
Community Member
We recently installed and will be migrating to a catalyst 3850 switch stack in our environment and need to know how to assign a subnet to a vlan?  I've looked in the documentation and being new to Cisco and CLI, couldn't see where to configure this.
Jon Marshall
You create the vlan at L2 in the vlan database -
switch(config)# vlan <vlan ID>
switch(config-vlan)# name <vlan name>
then you create a L3 interface for the vlan (SVI) -
switch(config)# int vlan <vlan ID>
switch(config-if)# ip address x.x.x.x <subnet mask>
then you allocate ports into that vlan and any clients are allocated an IP from the same subnet and their default gateway is the SVI IP address above.
Jon
