vlan suspend on nexux 3064
malmsteen81
Hi guys,
i have configured vpc with 2 nexus 3064 and worked fine for a couple of weeks. Yesterday i have powered off on siwtch to test network HA with VMware and after reboot the switch had  all interface vlan down.
i use a vlan with portchannel for keep alive
interface port-channel122
  description *** keepalive ***
  switchport mode trunk
  switchport trunk allowed vlan 23
n3k-ced-01# show int brief | i Vlan
Vlan1     --                                      down   VLAN/BD is down
Vlan23    --                                      down   suspended
the STP on first switch
LAN0023
  Spanning tree enabled protocol rstp
  Root ID    Priority    32791
             Address     0023.04ee.be01
             Cost        1
             Port        4217 (port-channel122)
             Hello Time  2  sec  Max Age 20 sec  Forward Delay 15 sec
  Bridge ID  Priority    32791  (priority 32768 sys-id-ext 23)
             Address     fc5b.39fb.9141
Interface        Role Sts Cost      Prio.Nbr Type
Po122            Root FWD 1         128.4217 P2p
and the vpc configuration is
vpc domain 1
  peer-switch
  peer-keepalive destination 192.168.23.2 source 192.168.23.1 vrf keepalive
  delay restore 360
  peer-gateway
  auto-recovery
  ip arp synchronize
so, why the SVI are down? i have tried  to shutdown and then active manually but they dont' work. i also deleted vlan23 and interface and created again but not luck.
thank you
Andrea
21 Replies 21
Muhammad Awais Khan
it sounds VPC configuration inconsistency to me. You can check the inconsistency by following:
show vpc consistency-parameters
it can be either mismatch on the vlans or VLAN SVI's. Make sure you have the same VLANs on both sides,
Some example output mentioned in below link might be useful
https://www.cisco.com/c/m/en_us/techdoc/dc/reference/cli/nxos/commands/vpc/show-vpc-consistency-parameters.html
hi, i have checked the vlan trunk on all port-channel and i found a mismatch. i have correct the problem and restart the first switch.
Now the vlan1 is up, but vlan23 (use for keep-alive is down).
vpc brief first nexus
n3k-ced-01(config)# sh vpc brief
Legend:
(*) - local vPC is down, forwarding via vPC peer-link
vPC domain id : 1
Peer status : peer adjacency formed ok
vPC keep-alive status : peer is not reachable through peer-keepalive
Configuration consistency status : success
Per-vlan consistency status : success
Type-2 consistency status : success
vPC role : secondary
Number of vPCs configured : 2
Peer Gateway : Enabled
Dual-active excluded VLANs : -
Graceful Consistency Check : Enabled
Auto-recovery status : Enabled, timer is off.(timeout = 240s)
Delay-restore status : Timer is off.(timeout = 360s)
Delay-restore SVI status : Timer is off.(timeout = 10s)
Operational Layer3 Peer-router : Disabled
vPC Peer-link status
id Port Status Active vlans
1 Po123 up 1,10,15-16,20-21,25-27,30,50-51,151-152,200
vPC status
Id Port Status Consistency Reason Active vlans
14 Po14 up success success 1,10,15-16,20-
21,25-26,30,50
-51,151-152,20
23 Po23 down* Not Consistency Check Not -
Applicable Performed
second nexus
n3k-ced-02# sh vpc brief
Legend:
vPC domain id : 1
vPC role : primary
vPC status
21,25-26,30,50
-51,151-152,20
23 Po23 down* success success -
n3k-ced-01(config)# show vpc consistency-parameters global
Legend:
Type 1 : vPC will be suspended in case of mismatch
Name Type Local Value Peer Value
STP MST Simulate PVST 1 Enabled Enabled
STP Port Type, Edge 1 Normal, Disabled, Normal, Disabled,
BPDUFilter, Edge BPDUGuard Disabled Disabled
STP MST Region Name 1 "" ""
STP Disabled 1 None None
STP Mode 1 Rapid-PVST Rapid-PVST
STP Bridge Assurance 1 Enabled Enabled
STP Loopguard 1 Disabled Disabled
STP MST Region Instance to 1
VLAN Mapping
STP MST Region Revision 1 0 0
Interface-vlan admin up 2 1 1,23
Interface-vlan routing 2 1 1,23
capability
QoS (Cos) 2 ([0-7], [], [], [], ([0-7], [], [], [],
Network QoS (MTU) 2 (9216, 9216, 9216, (9216, 9216, 9216,
9216, 9216, 9216) 9216, 9216, 9216)
Network Qos (Pause: 2 (F, F, F, F, F, F) (F, F, F, F, F, F)
T->Enabled, F->Disabled)
Input Queuing (Bandwidth) 2 (100, 0, 0, 0, 0, 0) (100, 0, 0, 0, 0, 0)
Input Queuing (Absolute 2 (F, F, F, F, F, F) (F, F, F, F, F, F)
Priority: T->Enabled,
F->Disabled)
Output Queuing (Bandwidth 2 (100, 0, 0, 0, 0, 0) (100, 0, 0, 0, 0, 0)
Remaining)
Output Queuing (Absolute 2 (F, F, F, F, F, F) (F, F, F, F, F, F)
F->Disabled)
Allowed VLANs - 1,10,15-16,20-21,25-27 1,10,15-16,20-21,25-27
,30,50-51,151-152,200 ,30,50-51,151-152,200
Local suspended VLANs - - -
Legend:
VLAN Mapping
capability
F->Disabled)
Remaining)
F->Disabled)
thanks
Andrea
hi
can you ping between the keep alive interfaces of vlan 23, once you can ping between them should come back up and be up int vpc brief
already tried but
n3k-ced-02# ping 192.168.23.1 vrf keepalive
PING 192.168.23.1 (192.168.23.1): 56 data bytes
36 bytes from 192.168.23.2: Destination Host Unreachable
Request 0 timed out
Request 1 timed out
Request 2 timed out
Request 3 timed out
Request 4 timed out
n3k-ced-01(config)# sh spanning-tree vlan 23
VLAN0023
             This bridge is the root
Po122            Back BLK 1         128.4217 P2p
n3k-ced-02# sh spanning-tree vlan 23
VLAN0023
Po122            Desg FWD 1         128.4217 P2p
on firs switch STP has blocked vlan23, but why? the vlan is tagged only on port-channel keep alive
23   keepalive                        active    Po122, Eth1/47, Eth1/48
The keepalive is a direct link yes ? just a vlan SVI with direct layer 2 port assigned to 23 connected between switches , interfaces are up yes
are you also sending that vlan over the peer link too ?
thats maybe why its blocked , looping somewhere between both switches , should only be seen on keepalive link
hi, the two nexus are connected directly with two cables on port 1/47-48 by port channel (122).
interface Vlan23
  no shutdown
  vrf member keepalive
  ip address 192.168.23.1/24
then peer-link has not access on vlan 23
interface port-channel123
  description *** VPC PEER LINKS ***
  switchport trunk allowed vlan 1,10,15-16,20-21,25-27,30,50-51,151-152,200
  spanning-tree port type network
  vpc peer-link
i can try to reboot the second nexus
Hello
@malmsteen81 wrote:
Hi guys,
LAN0023
             Cost        1
vpc domain 1
  peer-switch
  delay restore 360
  peer-gateway
  auto-recovery
  ip arp synchronize
Have you checked that the L2 vlans for the L3 interfaces are actually in the vtp database for these switchs and for some reason it hasnt been over wrote after the reload losing the l2 vlans would icurr the loss of connectivity you are reporting?
sh vlans
sh vtp status
Kind Regards
Paul
Hi, i don't use vtp
@malmsteen81 wrote:
Hi, i don't use vtp
Vtp is used to synchronize with the other switches if you dont use it then fine but do the switches have all the correct vlans in their vtp database, if not you need to re add them.
Another thing to try is to shutdown/restart the vpc domain to refesh the vpc.
Kind Regards
Paul
Ok peer looks fine ,before rebooting did you try bounce the interfaces , also Paul makes a good point confim your layer 2 database is ok for all vlans involved and something didnt happen on reboot of switch 1
hi, i have tried to add vlan23 on port-channel 123 (peer link) and vlan is waked up. But is correct allow vpc peer to keepalive traffic??
hello
not in the pc but in the L2 vlan database -
show vlan brief
Kind Regards
Paul
shouldn't be on the peer link no
keepalive doesent need to be a trunk either change it access as its only 1 vlan , on both sides
interface Vlan3003
description VPC Heartbeat
no shutdown
vrf member heartbeat
ip address x.x.x.x/30
interface Ethernet1/44
switchport
switchport access vlan 3003
logging event port link-status
no shutdown
