VLAN switch questions
z080236
Community Member
1. Let's say I have 2 subnets , 192.168.1.0/24 and 192.168.2.0/24, i want to configure interfaces 0/1 to 0/12 to VLAN1 to cater for 192.168.1.0/24 and interfaces 0/13 to 0/20 to cater for 192.168.2.0/24, the traffic from VLAN1 can communicate to VLAN2.
What is the CLI command for the above?
2. Let's say I have 2 same subnet , 192.168.2.0/24 ,
VLAN1 192.168.2.0/24 ports 0/1 to 0/12
VLAN2 192.168.2.0/24 ports 0/13 to 0/20
Traffic from VLAN1 should not be able to communicate to VLAN2.
How do I configure this in the CLI?
Mark Malone
You can use the interface range command to do multiple ports at once
interface range g0/1 - 12
switchport mode access
switchport access vlan 1
If you want to block the vlans speaking to each other the easiest way to do is probably an access list applied to the layer 3 SVI for those vlans and deny the subnets by ip speaking to each other
Just an example
interface vlan x
ip access-group 189 in
ip access-group 189 out
access-list 189 deny   ip 192.168.1.0 0.0.0.255 192.168.2.0 0.0.0.255
access-list 189 permit ip any any
The other way to do is use private vlans
http://www.cisco.com/c/en/us/support/docs/security/ios-firewall/23602-confaccesslists.html
