VLAN tagging and default untagged vlan
i'm moving from default untagged vlan to 2 vlan one for data, one for phones.
I was wondering, should I keep default untagged vlan or should i set the data one as default and then delete untagged vlan ?
Reza Sharifi
If you are referring to vlan 1 as the default vlan, don't use that.  Shut down vlan 1 and use 2 other vlans (10 and 20 for example) one for voice and one for data.
Reza Sharifi
