vlan traffic shaping
lewwalker
Visitor
Is there any way to traffic shape on local vlans...i familiar with traffic shaping on WAN however I never seen this procedure done on local vlan. Please keep in mind that I have a gig port with multiple vlans allow across however I would like lock down the pipe size per vlan ie 100mb of this gig pipe to various vlans.
Edison Ortiz
On a switch, shaping is generally done at the switchport, not at the SVI.
If you post the hardware in question, I may refer you to the correct documentation where options can be given for your task.
HTH,
__
Edison.
endymion12
Community Member
NetEqualizer shapes VLAN. It's "fully VLAN compatible." Have you looked into that? http://netequalizer.wordpress.com/2007/03/06/netequalizer-is-now-fully-vlan-compatible/
