VLAN trunk and native vlan - DHCP issue
JCAA
Hello
I'm trying to configure our Wifi infrastructure based on Ubuquiti access points, Ubiquiti controller and Cisco 9200L switches. Our 9200L is connected to our firewall. A default route as been configured to route all trafic to FW. Our DHCP server is hosted on our Windows server in other site.
The management IP address of Our AP are in the management network (VLAN1000). I created SSID "CorporateNET"  on the Unifi controller tagged with ID VLAN 30.
On the Unifi appl:
  • My access point is configured with static IP (10.0.2.12/255.255.255.0 ang GW 10.0.2.1) and the Management Network is configured to Default (Default is the network configured by default on the controller).
  • I created an a network "CorporateNET" and set the VLAN ID to 30
  • I created a SSID "CorporateNET" with "CorporateNET" network associated
On my 9200L switches, I have this configuration :
vlan 30
name CorporateNET
vlan 1000
name Management
interface Vlan30
 description CorporateNET
 ip address 10.0.30.1 255.255.254.0
 ip helper-address 10.31.10.10
 no ip redirects
 no ip proxy-arp
interface Vlan1000
 description NET_ADMIN
 ip address 10.0.2.1 255.255.255.0
 no ip redirects
 no ip proxy-arp
interface GigabitEthernet2/0/11
 description AP Wifi
 switchport trunk native vlan 1000
 switchport trunk allowed vlan 30,1000
 switchport mode trunk
switchport nonegotiate
 storm-control broadcast level 10.00
 storm-control multicast level 10.00
 storm-control action trap
 spanning-tree portfast trunk
 spanning-tree guard root
With this configuration when I connect my laptop to SSDI "CorporateNet", I reveive an IP on management network and no on the correct network (10.0.30.0/23). If I change the native vlan and switch from "switchport trunk native vlan 1000" to "switchport trunk native vlan 30", I have an IP on the correct network (10.0.30.0/23). I receive always the IP for the native vlan. But if I add other SSID with other networks, I will have problem..
If I configure an interface with access vlan30, my laptop receive the correct IP.
What is my error in the configuration ? And why,  when I configure switchport trunk native vlan 1000, when my laptop is connected on CorporateNET SSID, I don't received ip for the correct network ?
BR
11 Replies 11
Reza Sharifi
What if you make the port a trunk port and remove the native vlan command?  Example:
 description AP Wifi
If i remove native vlan, no ip delivered.
BR
I guess that is because the native command also exists on the firewall. If you remove the native command, it would have to be from both the switch and the firewall.
Where is the wireless controller? Is it also connected to the 9200 via a layer-2 trunk port?
No the controller is hosted on our IaaS Azure infrastructure. It's a windows server hosted on a dedicated host. Our DHCP is hosted in our on-prem datacenter in other site where we have access points
AP is run as standalone or control via WLC ?
The AP is managed by the Unifi controller
Your AP is control by WLC so go to their and check ssid-vlan mapping
If wlc push native vlan in ssid-vlan mapping so what you config as native vlan is take effect.
This not issue of ap nor sw it issue of controller mapping.
The configuration on the controller is very basic. I just created 1 network for management and 1 for CoporateNET and for each, the only settings are the network name, the vlan ID(the same number ID than vlan created on 9200L) and for gateway, it's default third-party gateway (it's a L2 gateway). I attached the management network to the AP and the CorporateNET network on the SSID CorporateNET.
Can I see control config of wlan
The wlan configuration on Ubiquiti controller?
Find here an attach files of my networks configuration on Unifi Controller and AP configuration..
