VLAN trunking issue
chaunce
Community Member
I'm having an issue allowing VLan 2 access on interaface Gi0/15. I've configured interface Gi0/15 with (switchport access vlan 2) on a 2960G-E Access switch. I've also configured the Access switch Trunk interface (Gi0/45) using switchport trunk allowed vlan add 2 as well as the Trunk interface the Access switch is connected to (Gi1/2) on a 4503 Distribution switch, but when I plug a device into Gi0/15 (I've tried multiple laptops that work when plugged into a different port albeit different VLans) on the Access switch, I see no meaningful traffic being passed. Any help troubleshooting this would be appreciated. If there are further commands you'd like me to execute, please let me know.
Thanks much,
Chauncey
DISTRIBUTION SWITCH
D301A-Cisco4503#sho int gi1/2 trunk
Port        Mode             Encapsulation  Status        Native vlan
Gi1/2       on               802.1q         trunking      7
Port        Vlans allowed on trunk
Gi1/2       1-3,6-7
Port        Vlans allowed and active in management domain
Gi1/2       1-3,6-7
Port        Vlans in spanning tree forwarding state and not pruned
Gi1/2       1-3,6-7
ACCESS SWITCH
D303-2960G-E#sho int gi0/45 trunk
Gi0/45      on               802.1q         trunking      7
Gi0/45      1-3,6-7
Gi0/45      1-3,6-7
Gi0/45      1-3,6-7
login as: admin
Using keyboard-interactive authentication.
Password:
D303-2960G-E>en
Password:
Gi0/45      1-3,6-7
Gi0/45      1-3,6-7
Gi0/45      1-3,6-7
D303-2960G-E#sho int gi0/15
GigabitEthernet0/15 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 0023.acf6.250f (bia 0023.acf6.250f)
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
  Keepalive set (10 sec)
  Full-duplex, 1000Mb/s, media type is 10/100/1000BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input never, output 00:00:00, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     2542731 packets input, 785961867 bytes, 0 no buffer
     Received 290742 broadcasts (84742 multicasts)
     0 watchdog, 84742 multicast, 0 pause input
     194896063 packets output, 141853440400 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
     0 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
D303-2960G-E#sho int gi0/15 status
Port      Name               Status       Vlan       Duplex  Speed Type
Gi0/15                       connected    2            full   1000 10/100/1000BaseTX
8 Replies 8
John Blakley
What's doing the routing for vlan 2?
HTH, John *** Please rate all useful posts ***
We're using an ASA 5520.
Can you ping the default-gateway ie. the ASA vlan 2 interface, from the PC you have connected to gi0/15 ?
Jon
Unfortunately, I can't test it right now, but I do remember trying this and receiving time outs or destination host unreachable. I'll be able to test this tomorrow and report back.
No problem.
Also, how is the firewall configured in terms of vlan 2 ie. do you have the inside interface supporting multiple vlans and if so is the connection from the 4500 to the firewall a trunk link that also allows vlan 2. I'm assuming the firewall is connected to the 4500.
Jon
Hi Jon,
Sorry for the delay. Pings to the ASA VLan 2 interface timeout from the PC connected to Gi0/15.
The inside/ASA VLan 2 interface only has VLan 2 on it. The firewall is connected to the 4500 (Gi3/3<->Gi0/2). BTW, pinging another host on VLan 2 from the ASA is successfull -100 percent repsonse.
D303-ASA5520(config)# sho int gi0/2
Interface GigabitEthernet0/2 "inside", is up, line protocol is up
  Hardware is i82546GB rev03, BW 1000 Mbps, DLY 10 usec
        Full-Duplex(Full-duplex), 1000 Mbps(1000 Mbps)
        Input flow control is unsupported, output flow control is off
        Description: VLan 2
        MAC address 001e.13f0.1750, MTU 1500
        IP address 10.1.20.1, subnet mask 255.255.255.0
        10982499084 packets input, 8973093431008 bytes, 0 no buffer
        Received 830936 broadcasts, 0 runts, 0 giants
        23868 input errors, 0 CRC, 0 frame, 23868 overrun, 0 ignored, 0 abort
        0 pause input, 0 resume input
        0 L2 decode drops
        7015135541 packets output, 1807805273466 bytes, 0 underruns
        0 pause output, 0 resume output
        0 late collisions, 0 deferred
        0 input reset drops, 0 output reset drops, 0 tx hangs
        input queue (blocks free curr/low): hardware (255/230)
        output queue (blocks free curr/low): hardware (255/8)
  Traffic Statistics for "inside":
        10982499086 packets input, 8774054509024 bytes
        7015135541 packets output, 1667986841803 bytes
        5758914 packets dropped
      1 minute input rate 456 pkts/sec,  309106 bytes/sec
      1 minute output rate 323 pkts/sec,  72207 bytes/sec
      1 minute drop rate, 0 pkts/sec
      5 minute input rate 584 pkts/sec,  300367 bytes/sec
      5 minute output rate 489 pkts/sec,  159776 bytes/sec
      5 minute drop rate, 0 pkts/sec
D301A-Cisco4503#sho int gi3/3 trunk
Gi3/3       off              negotiate      not-trunking  1
Gi3/3       2
Gi3/3       2
Gi3/3       2
D301A-Cisco4503#sho int trunk
Gi2/1       on               802.1q         trunking      7
Gi2/2       on               802.1q         trunking      7
Gi2/3       on               802.1q         trunking      7
Gi2/4       on               802.1q         trunking      7
Gi2/5       on               802.1q         trunking      7
Gi2/6       on               802.1q         trunking      7
Gi3/1       on               802.1q         trunking      1
Gi1/2       1-3,6-7
Gi2/1       1-2,4,7
Gi2/2       1,6-7
Gi2/3       1,7
Gi2/4       1,7-8
Gi2/5       1,3,6-7
Gi2/6       1,3,6-7
Gi3/1       1,3-4,6
Gi1/2       1-3,6-7
Gi2/1       1-2,4,7
Gi2/2       1,6-7
Gi2/3       1,7
Gi2/4       1,7-8
Gi2/5       1,3,6-7
Gi2/6       1,3,6-7
Gi3/1       1,3-4,6
Gi1/2       1-3,6-7
Gi2/1       1-2,4,7
Gi2/2       1,6-7
Gi2/3       1,7
Gi2/4       1,7-8
Gi2/5       1,3,6-7
Gi2/6       1,3,6-7
Gi3/1       1,3-4,6
Chauncey
can you post sh run interface gig3/3 on the 4503 switch.
Regards.
Alain
chaunce
Community Member
Hi Alain,
Here you go.
Chauncey
D301A-Cisco4503#sh run int gi3/3
Building configuration...
Current configuration : 139 bytes
interface GigabitEthernet3/3
description ASA FW VLAN 2
switchport mode access
speed 1000
duplex full
end
