VLAN tunnel question
strathglass
I have a Cisco switch configured with some ports forming a VLAN: for those ports, traffic never needs to leave the VLAN.
But now I want to connect DEVICE X to my home network, but it is only able to connect to a small Dahua switch that ties to the VLAN. This switch does not support 80211.Q and cannot be replaced. (See figure.)
What is the easiest solution to allow DEVICE X to reach the home network?
What extra hardware would I need and how would I configure it?
Keep in mind that I know very little of networking: a friend helped me with the initial Cisco configuration to get the VLAN setup.
I am assuming the easiest solution is one additional switch that can be configured to add the needed 802.1Q tagging, but I really have no idea.
Deepak Kumar
For en example: Device-X needs IP address from VLAN 10 than your configuration would be like:
interface gig 1/0/32
description Connected_Dahua_switch_Device_X
Switchport mode access
Switchport access vlan 10
spanning tree portfast
It will work for you.
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
