03-02-2020 08:48 AM
I have two switches I am trying to have them communicate with each other across a trunked port, but I cannot seem to give the non-native vlans to talk. Any assistance would be helpful. Vlan 1 will talk as long as it holds an IP on the SVI
C3750G - IP ROUTING ENABLED
C3560G - L2
C3750G
switch 1 provision ws-c3750g-24ps
system mtu routing 1500
ip routing
interface GigabitEthernet1/0/1
switchport mode trunk
interface Vlan1
interface Vlan2
ip address 192.168.2.1 255.255.255.0
interface Vlan10
ip address 192.168.10.1 255.255.255.0
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.99.254
Port Mode Encapsulation Status Native vlan
Gi1/0/1 on 802.1q trunking 1
Port Vlans allowed on trunk
Gi1/0/1 1-4094
Port Vlans allowed and active in management domain
Gi1/0/1 1-2,200
Port Vlans in spanning tree forwarding state and not pruned
Gi1/0/1 1-2,200
1 default active Gi1/0/2, Gi1/0/3, Gi1/0/4
Gi1/0/5, Gi1/0/6, Gi1/0/7
Gi1/0/8, Gi1/0/9, Gi1/0/10
Gi1/0/11, Gi1/0/12, Gi1/0/13
Gi1/0/14, Gi1/0/15, Gi1/0/16
Gi1/0/17, Gi1/0/18, Gi1/0/19
Gi1/0/20, Gi1/0/21, Gi1/0/22
Gi1/0/23, Gi1/0/24, Gi1/0/25
Gi1/0/26, Gi1/0/27, Gi1/0/28
2 VLAN0002 active
200 VLAN0200 activeC3560G
interface GigabitEthernet0/1
----------interface Vlan1
ip address 192.168.1.2 255.255.255.0
interface Vlan2
no ip address
interface Vlan10
no ip address
ip default-gateway 192.168.10.1
1 default active Gi0/3, Gi0/4, Gi0/5, Gi0/6
Gi0/7, Gi0/8, Gi0/9, Gi0/10
Gi0/11, Gi0/12, Gi0/13, Gi0/14
Gi0/15, Gi0/16, Gi0/17, Gi0/18
Gi0/19, Gi0/20, Gi0/21, Gi0/22
Gi0/23, Gi0/24, Gi0/25, Gi0/26
Gi0/27, Gi0/28
2 Server-Network active Gi0/2
10 Management active
Gi0/1 on 802.1q trunking 1
Gi0/1 1-4094
Gi0/1 1-2,10
Gi0/1 1-2,10
Solved! Go to Solution.
03-02-2020 09:11 AM
@TXITGUY9000 Hello
on switch:
ws-c3750g-24ps
vlan 10 as layer two is not created: create it.
on switch:
C3560G
default-gateway is wrong, change from 192.168.10.1 to 192.168.1.1.
If your test was started from switch to swich itself, it should work even the gateway is wrong, because they are in the same network.
03-02-2020 08:50 AM
Your default Gateway on the 3560G should be 192.168.1.1 not 192.168.10.1
03-02-2020 09:14 AM
@Kevin Martin wrote:Your default Gateway on the 3560G should be 192.168.1.1 not 192.168.10.1
Does the IP DEFAULT-GATEWAY require to be on the Native/Default VLAN?
03-02-2020 11:02 AM
On a L2 switch, yes. If you are communicating with the switch outside the native network, the default-gateway needs to be on the same network.
03-02-2020 09:07 AM
--> but I cannot seem to give the non-native vlans to talk.
Which Vlans cannot communicate ? Looking at your output, Vlan 10 doesn't exist on the 3750G, and on the 3560G there is no port assigned to Vlan 10.
Best to post the full running configurations of both switches...
03-02-2020 09:11 AM
@TXITGUY9000 Hello
on switch:
ws-c3750g-24ps
on switch:
C3560G
03-02-2020 09:37 AM
Please check :
- Gateways from both switches and readabilities each other.
- check if non native vlan are having assigned to proper ports ?
- if all good, share the output for - show int trunk
Thanks ,
Raja
