How to view logs from Cisco 2960 in CLI
fred2k3
My Cisco 2960 switch encountered issues over the weekend causing 2 of the ports to go into  Err-disable mode.
I have managed to rectify the problem, however I want to know if it's possible to view logs from the CLI to try and figure out what caused this.
I don't have any external logging servers setup, and I'm not even sure if it stores logs internally on the switch itself, and if so how long for.
Does anyone know if this is possible - and if so what are the commands I need to run from Telnet to access them please?
Mark Elsen
 - It would be strongly advisable to have this in place (logging to a syslog server). On the switch you can use show logging , but you cannot go all the way back in time. A syslog server offers more flexibility on this.
M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Mark Elsen
M.
       Beauty and terror
      Just keep going
       No feeling is final
Show logging is not a CLI command.
Seb Rupik
You can increase the log buffer size on the switch as a future precaution, but @Mark Elsen suggestion is the best regards to logging.
Whilst the switchport is still err-disabled, the command sh int status err-disabled will give some greater insight into particular reason.
cheers,
Seb.
Dennis Mink
For diagnoatic puropses you add the "logging console" command in your comfig and do no logging console to turn off again
Please remember to rate useful posts, by clicking on the stars below.
