VLANs not routing to eachother - 3750
pgkool001
Hello all,
I am new to cisco and IOS so bear with me. I have just purchased a 24 port catalyst 3750 and am trying to create two VLANs and get them to talk to each other.
VLAN1 is connected to a consumer grade netgear router which is in turn connected to my internet. This is the 192.168.1.0/24 subnet.
VLAN3 is the 192.168.3.0/24 subnet which I want to be able to access the internet.
Just trying to do some basic pinging between the two VLANs is unsuccessful, and VLAN 3 can not reach the internet. Please help. I will follow up with some snippet of my configuration.
TIA
P
2 Accepted Solutions
Abzal
Level 7
Level 7
Configure port connected to netgear as:
int g1/0/x
switchport mode access
So that two devices will be on one subnet 192.168.1.0/24. Then assign to netgear's interface which is connected to 3750 IP address from 192.168.1.0/24 subnet (in you configuration I assume it is 192.168.1.1/24). Then you need to put on netgear static IP route to your local subnet 192.168.3.0/24 and point it to IP address of 3750 which is 192.168.1.250/24.
Best regards,
Abzal
So you are saying a device on the 192.168.1.x network cannot talk to a device on the 192.168.3.x network. or is the 192.168.1.x network just used as a link to your Netgear?
As Abzal said below you need to be able to configure a route on the Netgear back to the 192.168.3.x network, and must allow the 192.168.3.x network to be NATed on the Netgear for a public address.
9 Replies 9
pgkool001
SHOW VERSION:
Cisco IOS Software, C3750 Software (C3750-IPBASEK9-M), Version 12.2(55)SE10, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Wed 11-Feb-15 11:40 by prod_rel_team
Image text-base: 0x01000000, data-base: 0x02D00000
ROM: Bootstrap program is C3750 boot loader
BOOTLDR: C3750 Boot Loader (C3750-HBOOT-M) Version 12.2(44)SE5, RELEASE SOFTWARE (fc1)
3750switch uptime is 2 weeks, 4 days, 1 hour, 50 minutes
System image file is "flash:c3750-ipbasek9-mz.122-55.SE10/c3750-ipbasek9-mz.122-55.SE10.bin"
pgkool001
SHOW VLAN BRIEF:
3750switch#show vlan brief
VLAN Name                             Status    Ports
1    default                          active    Gi1/0/1, Gi1/0/2, Gi1/0/3
                                                Gi1/0/4, Gi1/0/6, Gi1/0/7
                                                Gi1/0/8, Gi1/0/9, Gi1/0/10
                                                Gi1/0/11, Gi1/0/12, Gi1/0/13
                                                Gi1/0/14, Gi1/0/16, Gi1/0/17
                                                Gi1/0/18, Gi1/0/19, Gi1/0/20
                                                Gi1/0/21, Gi1/0/22, Gi1/0/23
                                                Gi1/0/24, Gi1/0/25, Gi1/0/26
                                                Gi1/0/27, Gi1/0/28
2    work                             act/lshut
3    garage                           active    Gi1/0/5, Gi1/0/15
10   home                             act/lshut
11   rooms                            act/lshut
1002 fddi-default                     act/unsup
1003 token-ring-default               act/unsup
1004 fddinet-default                  act/unsup
1005 trnet-default                    act/unsup
pgkool001
SHOW IP ROUTE:
3750switch#show ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is 192.168.1.1 to network 0.0.0.0
C    192.168.1.0/24 is directly connected, Vlan1
C    192.168.3.0/24 is directly connected, Vlan3
S*   0.0.0.0/0 [1/0] via 192.168.1.1
pgkool001
SHOW RUNNING-CONFIG:
3750switch#show running-config
Building configuration...
Current configuration : 3903 bytes
version 12.2
<-- OUTPUT SUPPRESSED-->
hostname 3750switch
boot-start-marker
boot-end-marker
no aaa new-model
clock timezone UTC -5
clock summer-time UTC recurring
switch 1 provision ws-c3750g-24ts
system mtu routing 1500
shutdown vlan 2
shutdown vlan 10
shutdown vlan 11
ip routing
ip dhcp excluded-address 192.168.3.3 192.168.3.254
ip dhcp pool vlan3
   network 192.168.3.0 255.255.255.0
   default-router 192.168.3.1
spanning-tree mode pvst
vlan internal allocation policy ascending
interface GigabitEthernet1/0/1
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
 switchport access vlan 3
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
interface GigabitEthernet1/0/25
interface GigabitEthernet1/0/26
interface GigabitEthernet1/0/27
interface GigabitEthernet1/0/28
interface Vlan1
 ip address 192.168.1.250 255.255.255.0
interface Vlan2
 ip address 192.168.2.1 255.255.255.0
interface Vlan3
 ip address 192.168.3.1 255.255.255.0
interface Vlan10
 ip address 192.168.10.1 255.255.255.0
interface Vlan11
 ip address 192.168.11.1 255.255.255.0
ip default-gateway 192.168.1.1
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.1.1
ip http server
ip http secure-server
end
Abzal
Level 7
Level 7
int g1/0/x
Best regards,
Abzal
pgkool001
Thankyou Abzal and Richard!
I added a static route on my netgear to direct 192.168.3.0/24 traffic to the cisco switch, 192.168.1.250. That did the trick for pinging. I should have thought of this, I think my setup is a bit wonky. So let me clarify.
Internet
Netgear Router (192.168.1.1)
Cisco Switch (192.168.1.250)
VLAN1(192.168.1.250)       VLAN3 (192.168.3.1)
Gateway: 192.168.1.1         Gateway: 192.168.3.1
So my ping traffic was routing to the netgear, but it had no route back to the switch. This is now fixed, and I can ping between VLANs!
I set the default DNS server on the 192.168.3.0/24 VLAN to be 192.168.1.1, this allowed me to do DNS lookups, and that works.
However, I still can not access the internet, I think this is as Richard said, the net gear needs to be able to NAT the 192.168.3.0/24 subnet, and I'm not sure how to do this. I'll do some research on google, but I guess its outside the scope of this forum.
So I think my road ends here, unless someone has some bright suggestions on what to do on the 3750 to spoof this?
pgkool001
Just FYI for anyone else who stumbles on this...my netgear router...nighthawk R7000 does not support outside subnet NATing supposedly. I posted on the netgear forums and found out that  I needed the 3'rd party firmware to get this to work. I put asusWRT-Merlin on my router and now I can get the VLANs to access the internet. All is well!!!
See post below:
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/NAT-for-different-subnet/m-p/1018538/highlight/false#M22922
Hi all.. understanding this post is a year old but needs some help pls.
I have the similar configuration as pgkool001, with Main router R7000 running Asuswrxt Merlin, connected to a switch with VLANs. All my VLANs can communicate with each other and with devices on router network.
The issue I face is the devices on VLAN cannot route to internet. I understand I need to do some NATing on Asuswrxt router but I'm not 100% on how? Script to run?
Please advise.
CT
