vlans on 2950 dhcp ?
I will try to descibe what i want
two vlan2
vlan 10 is using 192.168.21.x network
vlan 40 is using 192.168.11.x network
some ports I want to have in 10 network and some as trunk to Accesspoints
my access points are on 18 till 22
and two ports that go to their ISP routers.
below is the config.
My issue, DHCP and traffic from accesspoints don't work.
what am i doing wrong ?
spanning-tree mode pvst
no spanning-tree optimize bpdu transmission
interface FastEthernet0/1
 description naar Grandstream GW1
 switchport access vlan 10
 switchport mode access
interface FastEthernet0/2
 description naar Grandstream GW2
interface FastEthernet0/3
 description naar 3CX Server
interface FastEthernet0/4
 description naar Wireless controller
interface FastEthernet0/5
 description naar Video opname
interface FastEthernet0/6
 description naar video opname extern
 switchport access vlan 40
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/16
 description to adsl router
interface FastEthernet0/17
 description to poe switch
interface FastEthernet0/18
 description to wifi AP
 switchport trunk native vlan 10
 switchport trunk allowed vlan 10,40
 switchport mode trunk
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
 description naar enginius ander gebouw
interface FastEthernet0/23
 description naar 3e verdieping
interface FastEthernet0/24
 description naar isp router
interface Vlan1
 no ip address
 no ip route-cache
 shutdown
interface Vlan10
 ip address 192.168.21.5 255.255.255.0
 ip helper-address 192.168.21.1
 no ip route-cache
interface Vlan40
 no ip address
 ip helper-address 192.168.11.1
 no ip route-cache
 shutdown
ip default-gateway 192.168.21.1
Nut sure if I understand u right. But let's try ;).
dhcp problem on all ports. Add the following "spanning-tree portfast enable
your interface vlan 40 is shutdown. So it will not work also for dhcp. But u can only enable one svi on that kind of switch. As long as your dhcp is on the same vlan you don't need an ip helper.
Didn't think about that.
Will change it tomorrow and give it a try.
on the vlan 40
On the 2950 I can get only one ip address enabled on a vlan.
But I only need one (for management of the switch).
so I should be able to give on vlan 40 and vlan 10 separate dhcp right ?
i have a port in access mode 10 with dhcp from a draytek
and another port in access mode 40 with dhcp from an cisco cable modem.
further comments on this welcome ?
problem solved, it was the spanning tree portfast line
regarsd
martin
