VM host issues connected to pair of VPC switches using HSRP
CiscoBrownBelt
Level 6
Level 6
So I have a couple hosts  that continuous pings (testing do to deployment issues) fail mostly from doing pings from servers.
Just have a pair of 3548 Nexus in VPC domain (configured to be active active) and routing for the subnet hosts are in is done via SVI-HSRP. Here are pertaining configs. Any help guys?
Same on both switches except:
vpc domain 1
  role priority 100 (same for both switches)
  peer-keepalive destination 172.168.1.1 source 172.168.1.2 vrf vpc-keepalive
  dual-active exclude interface-vlan 5
  peer-gateway
  auto-recovery
interface port-channel1
  vpc peer-link
SVI configs
Same on both switches except where noted:
interface Vlan2
  description ServerHost
  no shutdown
  no ip redirects
  ip address 172.168.2.2/24
  hsrp 2
    preempt
    priority 105 (priority default on Switch 2)
    ip 172.16.2.1
interface Ethernet1/45 and 46
  description vPC Peer-Link
  switchport mode trunk
  channel-group 1 mode active
  no shutdown
Interfaces for server ports:
interface Ethernet1/1 and 2
  speed 1000
  switchport trunk allowed vlan 2
 switchport trunk native vlan 12
  spanning-tree port type edge trunk
  no shutdown
SHOW Commands to help T-shoot:
show mac address-table (trouble host mac)
Sw_A# sh mac address-table | inc 03a0.9756.056d
* 214      03a0.9756.056d    dynamic   0          F    F  Po1
Sw_B# sh mac address-table | inc 03a0.9756.056d
Sw_A# sh port-channel traffic
ChanId      Port Rx-Ucst Tx-Ucst Rx-Mcst Tx-Mcst Rx-Bcst Tx-Bcst
    1   Eth1/35   0.07%   0.80%   2.25%   3.75%   0.12%   0.52%
    1   Eth1/36  99.92%  99.19%  97.74%  96.24%  99.87%  99.47%
Sw_B# sh port-channel traffic
    10   Eth1/35  55.87%  19.73%  16.15%  47.77%  98.40%  99.75%
    10   Eth1/36  44.12%  80.26%  83.84%  52.22%   1.59%   0.24%
16 Replies 16
Yes, good idea to add it.
from the document
Note: For proper behavior, VLAN priorities on both Nexus 7000 switches should be configured the same.
in your case they are 3000 switches but that does not matter.
So, in addition to the peer-switch command, you have to make sure that vlan priorities are the same for both switches.
here is a link to the doc
https://www.cisco.com/c/en/us/support/docs/routers/7000-series-routers/116140-config-nexus-peer-00.html#anc6
Ok will do. Think there is a disruption when adding it as I am not sure and will need a window if so.
from the document
Ok priorities are the same but as stated I will add the peer-switch command.
