VM trunk port errors
maxnpj
Level 3
Level 3
I think this may be an easy question.....if I'm trunking a switchport  that is connected to a VM instance, will I see interface errors on that trunk port? (input errors, CRC errors, etc)
--Brian
sdheer
Hi Brian,
Seeing the input errors or teh CRC errors are not related to the VM instance specifically
CRC and input errors increment when a device recieves corrupt frame from the other end.This is a indication of the physical layer issue ie bad cable or bad port or bad NIC .
Hope that answers your query.
Swati
Please rate helpful posts
Swati Dheer;
Thank you for your answer. I think that gets me the information I was looking for. We have a port that has not had counters cleared in 3y50w and there is not 1 input error, not 1 CRC or framing error. While that is good...it seemed odd that there wasn't at least one.
I'm not complaining...just making sure that i am interpreting what I see correctly.
