VMPS
NSG_POLARIS
Hi Everybody,
I am using VMPS in my LAN for security.
Can any one let me know if the VMPS has End of Life ?
Thanks in advance
Gopinath.J
Hi Friend,
AFAIK technology is never end of life or support till the time the product on which you are using has a valid support and not end of life or support.
Ankur
*Pls rate all helpfull post
ankbhasi
Hi Gopinath,
The VMPS feature is no longer supported in 12.2SX code.
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/122sx/ol_4164.htm#wp25624
The alternative as I see it would be to enable 802.1x authentication on the switch and authenticate users or machines against a RADIUS server. From there, you can perform vlan ssignment.
Here is the configuration guide for 802.1x on this platform:
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/122sx/swcg/dot1x.htm
Ankur
My understanding from your reply is 12.2SX and later ios will not support vmps.
QUERY:- Can cisco give tech-support if I continuing the VMPS with lower version on the Switch?
Hi Friend,
Ankur
