voice card not initializing
vinodgasianet
Community Member
I have recently got a router - 1751v
and also a voice card - vip2-2fxs
The card is not getting initialized
error showing card not initializing, unknown hardware found in slot1.
is there any patch for the card to be initialized
pls reply
amit-singh
Level 11
Level 11
Hi Vinod,
Please check the IOS version ruuning on the router. I think you are talking about vic-2fxs card.
Please paste the shwo version from your router. I think the IOS version running on your router doesnot support that card.
HTH, please rate if it does.
-amit singh
Hi Amit,
Thank you for ur response
here is the sh tech support details of the router
the card is vic-2fxs
------------------ show version ------------------
IOS (tm) C1700 Software (C1700-SV8Y-M), Version 12.2(13)T16, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Thu 14-Apr-05 19:25 by yiyan
Image text-base: 0x80008120, data-base: 0x81190E44
ROM: System Bootstrap, Version 12.2(7r)XM2, RELEASE SOFTWARE (fc1)
ROM: C1700 Software (C1700-SV8Y-M), Version 12.2(13)T16, RELEASE SOFTWARE (fc1)
yourname uptime is 4 minutes
System image file is "flash:c1700-sv8y-mz.122-13.T16.bin"
cisco 1751 (MPC860P) processor (revision 0x400) with 83979K/14325K bytes of memory.
Processor board ID FOC08310YEZ (1669471188), with hardware revision 0000
MPC860P processor: part number 5, mask 2
Bridging software.
X.25 software, Version 3.0.0.
1 FastEthernet/IEEE 802.3 interface(s)
2 Serial(sync/async) network interface(s)
32K bytes of non-volatile configuration memory.
32768K bytes of processor board System flash (Read/Write)
------------------ show diag ------------------
Slot 0:
C1751 1FE VE DV Mainboard Port adapter, 3 ports
Port adapter is analyzed
Port adapter insertion time unknown
EEPROM contents at hardware discovery:
Hardware Revision : 4.0
PCB Serial Number : FOC08310YEZ
Part Number : 73-7241-04
Board Revision : B0
Fab Version : 04
Product Number : Unknown
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF 40 02 4D 41 04 00 C1 8B 46 4F 43 30 38 33
0x10: 31 30 59 45 5A 82 49 1C 49 04 42 42 30 02 04 FF
0x20: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x30: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Packet Voice DSP Module Slot 0:
Hardware Revision : 3.2
Part Number : 73-6726-01
Board Revision : A0
Deviation Number : 0-0
Fab Version : 03
PCB Serial Number : VIC09267FBE
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Processor type : 02
Number of DSP's : 1
DSP memory size(in kwords): 256
Type of DSP : TMS320C549
Product Number : PVDM-256K-4=
0x00: 04 FF 40 02 AC 41 03 02 82 49 1A 46 01 42 41 30
0x10: 80 00 00 00 00 02 03 C1 8B 56 49 43 30 39 32 36
0x20: 37 46 42 45 03 00 81 00 00 00 00 04 00 09 02 FF
Packet Voice DSP Module Slot 1:
Not populated
WIC/VIC Slot 0:
Serial 2T (12in1)
Hardware revision 1.0 Board revision D0
Serial number 0024047013 Part number 800-03181-01
FRU Part Number WIC-2T=
Test history 0x00 RMA number 00-00-00
Connector type PCI
EEPROM format version 1
0x20: 01 12 01 00 01 6E ED A5 50 0C 6D 01 00 00 00 00
0x30: 68 00 00 00 00 10 12 00 FF FF FF FF FF FF FF FF
can u pls help....
