Voice & Data VLAN Configuration
Greetings, We had a vendor install all our switches and I've found that the switch configurations for voice & data are a little different. They are configured either as (where vlan 10 = data, vlan 172 =voice):
interface FastEthernet0/2
switchport access vlan 10
switchport mode access
switchport voice vlan 172
mls qos trust dscp
spanning-tree portfast
OR....
interface GigabitEthernet0/6
switchport trunk native vlan 10
switchport mode trunk
mls qos trust dscp
I've also see the voice configured as:
switchport access vlan 172
And some ports (that are not connected to 'static' devices such as a router) configured with switchport mode trunk, and also had voice running on it.
I'm trying to get all configurations consistent across the board. Can anyone tell me if there is a best way to approach this? Is one configuration going to give better performance than another?
Chris
P.S. The switches are Catalyst 3650, running 12.2 (35)SE5 IOS.
Reza Sharifi
Hi Chris,
For your first solution, Cisco calls this a Multi-Vlan access port, and NOT a trunk port. But we all know if you have more then one vlan on the port then it is trunk.  I would go with your second option:
mls qos trust dscp
https://supportforums.cisco.com/thread/1003209?tstart=30
Reza
