voice qos
mialbert
I have a c1811isr that i am wanting to set up a voice qos on such that voice gets 60% of traffic and all other web traffic gets 40%.  Below is the configuration i'm proposing to use.  Will this do it or is there something more?
class-map match-any HTTP
match protocol http
match protocol secure-http
class-map match-any SDM-Transactional-1
match protocol citrix
match protocol finger
match protocol notes
match protocol novadigm
match protocol pcanywhere
match protocol secure-telnet
match protocol sqlnet
match protocol sqlserver
match protocol ssh
match protocol telnet
match protocol xwindows
class-map match-any SDM-Signaling-1
match protocol h323
match protocol rtcp
match protocol sip
class-map match-any SDM-Routing-1
match protocol bgp
match protocol egp
match protocol eigrp
match protocol ospf
match protocol rip
match protocol rsvp
class-map match-any SDM-Voice-1
match protocol rtp audio
class-map match-any SDM-Management-1
match protocol dhcp
match protocol dns
match protocol imap
match protocol kerberos
match protocol ldap
match protocol secure-imap
match protocol secure-ldap
match protocol snmp
match protocol socks
match protocol syslog
policy-map SDM-QoS-Policy-1
class SDM-Voice-1
  set dscp ef
  priority percent 60
class SDM-Signaling-1
  set dscp cs3
  bandwidth percent 60
class SDM-Routing-1
  set dscp cs6
  bandwidth percent 5
class SDM-Management-1
  set dscp cs2
  bandwidth percent 5
class SDM-Transactional-1
  set dscp af21
  bandwidth percent 5
class HTTP
  priority percent 40
class class-default
  fair-queue
  random-detect
policy-map SDM-QoS-Policy-2
class class-default
  shape average 1544000
  service-policy SDM-QoS-Policy-1
interface FastEthernet1
description $FW_OUTSIDE$$ETH-WAN$
ip address xxxx x.x.x.x.
ip access-group out-in in
ip verify unicast reverse-path
ip nat outside
ip inspect SDM_LOW out
ip virtual-reassembly
duplex auto
speed auto
snmp trap ip verify drop-rate
service-policy output SDM-QoS-Policy-2
11 Replies 11
JohnTylerPearce
Level 7
Level 7
So from looking at your configuration, you are shaping the default class to a T1 speed basically, and are nesting the
SDM-QoS-Policy-1 policy map.
I did notice an issue with the configuration.
class SDM-Voice-1
  set dscp ef
  priority percent 60
  set dscp cs3
class SDM-Routing-1
  set dscp cs6
  bandwidth percent 5
  set dscp cs2
  bandwidth percent 5
  set dscp af21
  bandwidth percent 5
class HTTP
  priority percent 40
class class-default
  fair-queue
  random-detect
class class-default
On both of those you are using 'priority percent' where I would think you only want that on your Voice traffic.
If you do "priority" you are configuring LLQ, so you really arent doing any CBWFQ. It wll service that queue first as long as there are packed within the queue, and not even worry about the other ones.
So if you have Voice 60% and HTTP 40% both using LLQ, then you could potentially starve out traffic. I would put 'bandwidth percent 40" on HTTP in your setup. Using the 'bandwidth' command will allow you to use other queues if they are not being utilized unlike LLQ.
Joseph W. Doherty
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
It appears from you posting, your router is actually running this QoS configuration, correct?
If so, I'm surprised as you've allocated more than 100% of the bandwidth.
Besides what John has noted, i.e. you probably don't want LLQ for HTTP traffic, if you allocate 60% and 40%, you don't intend to set aside any bandwidth for any other traffic?
Cisco recommends not to allocate more than about 1/3 of the bandwidth for LLQ; this to allow bandwidth for other traffic.  But even if that's not an issue, when you start to get into high LLQ allocations, you might not have enough bandwidth for any burstyness of your LLQ traffic.  (Much depends on the nature of that traffic.)
Some other suggestions:
If you shaping for a T1, as I believe most shapers don't account for L2 overhead, you'll want to shape somewhere in the range of 5 to 15% slower; this becomes more important when dealing with "sensitive" traffic, like VoIP.
I consider the full autoQoS (and corresponding QoS model) often overkill.  You might find:
class SDM-Voice-1
  set dscp ef
  priority percent #
class class-default
  fair-queue
sufficient for your child policy.
Thanks.  Actually this is not for a t1.  It is for a 30mb down circuit.  Will change the shape average accordingly.
How would i specify the shape average command if this is a 30mb down 10mb up circuit?
Disclaimer
Posting
You would shape your egress for 10 Mbps (optionally with an allowance for L2 overhead, as decribed in my earlier post).
Would you shape the ingress and egress seperately?  The policy is bound to the outside interface so wouldn't this apply to ingress(inbound)traffic as well?
Disclaimer
Posting
You cannot shape ingress, although you can police it.
If you're trying to manage ingress bandwidth, policing ingress is not always effective, as the policing is done after the packets have come down your link. (If your provider is limiting you to 30 Mbps down, they would normally restrict your bandwidth such that it cannot exceed the limit.  One reason why you might still police ingress, would be to police some "bad" traffic to some limit, less than the provider's limit, trying to insure "good" traffic will have some available down bandwidth.)
I am getting the following when trying to enter the revised config:
c1800(config)#policy-map SDM-QoS-Policy-1
c1800(config-pmap)#class SDM-Voice-1
c1800(config-pmap-c)#  set dscp ef
c1800(config-pmap-c)#  priority percent 60
c1800(config-pmap-c)#class SDM-Signaling-1
c1800(config-pmap-c)#  set dscp cs3
c1800(config-pmap-c)# bandwidth percent 60
Sum total of class bandwidths exceeds 99 percent
c1800(config-pmap-c)#class SDM-Routing-1
c1800(config-pmap-c)#  set dscp cs6
c1800(config-pmap-c)#  bandwidth percent 5
c1800(config-pmap-c)#class SDM-Management-1
c1800(config-pmap-c)#  set dscp cs2
c1800(config-pmap-c)#class SDM-Transactional-1
c1800(config-pmap-c)#  set dscp af21
c1800(config-pmap-c)#class HTTP
c1800(config-pmap-c)#  bandwidth percent 40
c1800(config-pmap-c)#class class-default
c1800(config-pmap-c)#  fair-queue
c1800(config-pmap-c)#  random-detect
It will not enter the boldened bandwidth percent commands for the respective classes.  What is it adding up to get it exceeding 99%?  What i'm trying to do is allocate a little more for voice than all else(http).  I was thinking voice 60% and http 40%.
Disclaimer
Posting
I'm wondering whether you've fully read my prior postings and understood them.  If something I wrote was unclear, questions are always welcome.
In my first posting:
And so, you try to apply the policy and get an error, eh?
Sum of bandwidth allocations cannot exceed 100%.
60% (for SDM-Voice-1) and 60% (for SDM-Signaling-1) = 120% which is greater than 100%.
Okay, and also from my first posting:
... if you allocate 60% and 40%, you don't intend to set aside any bandwidth for any other traffic?
So if i do the following as below
class SDM-Voice-1
  set dscp ef
  priority percent 10
  set dscp cs3
  bandwidth percent 10
class SDM-Routing-1
  set dscp cs6
  set dscp cs2
  set dscp af21
class HTTP
  priority percent 35
class class-default
  fair-queue
  random-detect
I am allocating 50% to voice, 35% to http and 15% to all else.  Is this correct?
Disclaimer
Posting
35% for http, yes.
50% voice, no.
15% all else, no.
