VOIP lan design
Benoy Mandal
I am required do a lan design for a 500 phone on a non converged environment.
1) There will be 100 phone on each floor.
The phones will be using g729 as preferred codec.
2) Fibre will be used uplink these switches.
3)A 10mb WAN connected will be used to send VOIP RTP and SIGNALLING over a MPLS network towards and SIP based Call manager.
I need to know what switches and router models I can use for this degsign.
Do I need a standalone DHCP server or Can I use the router as DHCP server.?
What QOS consideration is required on switch and the router to optimise the VOIP?
What is model of the LAN I need to follow to achieve a resilient design?
Any feedback is much appreciated.
Benoy
xcz504d1114
Level 4
Level 4
You can use a router to provide DHCP, just make sure you specify Option 150 in the DHCP scope whether you use the router or another service, Option 150 allows specification of the call manager servers so the phones can download their configs.
Switches, you can ran any PoE switch, 3750 or 3560. The 100 meg switches are significantly cheaper than the ones with gigabit connections to the desktops, and depending on what phones are going to be installed, not all phones support gig connections anyways.
For QOS on the switches, you are talking about CoS (Class of Service). Autoqos is your best option, theres really no need to do anything other than that.
http://www.cisco.com/en/US/technologies/tk543/tk879/technologies_white_paper0900aecd800a8561.html
For QOS on routers you are talking about DSCP, and again Autoqos is the way to go.
http://www.cisco.com/en/US/docs/ios/12_2t/12_2t15/feature/guide/ftautoq1.html
For resilency, obviously any redundant topology links will benefit you. If you loose communication to your call manager there is a technology called SRST you can configure on the routers, which will in essence continue handling the VoIP until call manager communication is restored.
http://www.cisco.com/en/US/products/sw/voicesw/ps2169/tsd_products_support_series_home.html
Also with your router choice, if you choose something such as a 2801 or 2811, you can get FXO and FXS cards, this will allow you POTS (analog) phone capability if you loose your PRI or uplink. You can use those analog ports for 911 services and in conjunction with SRST configurations.
I hope that helps get you in the right direction,
Craig
