VOIP traffic prioritization
bfpnetworking
Hi all.  I have a new VOIP implementation using 2960 switches.
I want to prioritize voice traffic.
After creating VLAN 2 I did the following:
Per Cisco, I did the following on my uplink ports:
switchport trunk allowed vlan 1,2
switchport mode trunk
switchport nonegotiate
priority-queue out
mls qos trust cos
priority-queue out
mls qos trust cos
spanning-tree portfast trunk
spanning-tree bpduguard enable
On my ports where a VOIP phone was plugged in, I did the following:
priority-queue out
mls qos trust cos
How can I verify that my voice traffic is being prioritized?
5 Replies 5
andrew.prince
Level 10
Level 10
I think you should read the below link:-
http://www.cisco.com/univercd/cc/td/doc/solution/esm/qossrnd.pdf
HTH>
I forgot to add that I am only using VOIP on the LAN.
Are you using Cisco phones?
No.  We are using Non-Cisco phones.
Ok, I would recommend reading this document before deploying VoIP.  The first section provides a great amount of details of interaction between the phone and the switch.  It is intended for Cisco phones, but the QOS parameters provided by other vendors's phone should be the same.
http://www.cisco.com/en/US/docs/solutions/Enterprise/WAN_and_MAN/QoS_SRND_40/QoSCampus_40.html
