VOIP
Najeeb Stanikzai
Community Member
Hello All,
i would like to setup VOIP for my office, can you please tell me what is the requirements.
17 Replies 17
Leo Laohoo
Not enough info.
1.  What's your funding?
2.  How many people in the building?
3.  What kind of WAN bandwidth?
4.  What kind of LAN speed?
5.  Is this exercise part of your schoolwork?
1.dont know about funding yet.
2. we need at least 50 connection
3.LAN speed is gig and 10 gig.
4 this is required for our office.
Thanks for your quick reply
I believe this question will determine whether you go stand-alone, CME, CUCM, CUE, etc.
Different solution for different pain price points.
i am asking what devices are using for Cisco Voip.
Phones portfolio can be found HERE.
how about Cisco Router or Switch does it required for VOIP ?
2900 and 3900 routers can support CME.
As for switch, depends on your budget.  Most important thing to consider for switches are:
1.  How many phones per switch;
2.  What particular model of phones (some phones draw less than 15.4w and some draw up to 20.0w);
This will decide if you need an "FP" (Full PoE) switch or standard PoE.
So many factors to consider but it will depend entirely on your budget.
Thank you so much for your information.
we need to 100 connection for VOIP and switch should be POE.
Please let me know which router and switch can support VOIP.
Thanks again.
Hello, Ahmad Jan.
What handsets are you going to use?
Do you need 10GE for uplink ports? I suggest the SG500X models if you are going to fill all ports with phones. 375w total from PoE devices and all 48 support PoE. Also for supporting QoS, Stackable and already Layer 3 switches.
Thanks!
Thank you for your response,
i would like to setup VOIP for my office. but i wanted to know what cisco devices required for it.
Like Cisco router,Cisco Switch,Handset ?
i want to install 1 handset for per office and total we have 100 offices.
Ahmad Jan
1.  All Cisco switches can support VoIP deployment (PoE or non-PoE).
2.  All routers can support VoIP.
The major question that needs to be answered is WHAT IS YOUR BUDGET.
Your switch can be a chassis-based or individual based.  Can be Instant Access or regular IOS.
Dear Leo,
this is not homework, actually i had training of VOIP in 2009 that was theory not practical therefore i forgot it, as you asked for the budget i found it we have 14000 $ budget for it, i posted this question because i would like to know about VOIP and devices model and cost .
i hope this is enough,
please let me know your recommendation about the Cisco devices.
$14000 for 100 handsets, router(s) and switches (and possibly Cisco call servers)????
I think this is a joke.
Ok, I'm sitting this out.  So far, I really don't see this is a real deployment.  I've seen your previous thread and I'm still convinced this is a school work.
This is not Joke dear.
Please send me your email i will communicate through my official email.
