vPC on multiple nexus 5010/5020
tiwang
Level 4
Level 4
Hi out there
I have a set of Nexus 5020 (and also 5010) with a vPC between - - this means that the nx50201 and nx50202 is interconnetec with a vPC
Now a got a second - redundant for DR - set of nexus 5020 - configured identical - which means that they also have a vPC between then which runs fine. Now would I like to interconnect the two set of switches with a vPC also - so that I also have a vPC between them but the limitation for the vPC is max 2 switches in a single vPC - is there a way to trick this so that I could have a vPC between my redundant set of switches also?
best regards /ti
Reza Sharifi
Yes, the limitation is still 2 devices.
You can have only two devices as vPC peers; each  device can serve as a vPC peer to only one other vPC peer. The vPC peer  devices can also have non-vPC links to other devices.
http://www.cisco.com/en/US/docs/switches/datacenter/sw/4_2/nx-os/interfaces/configuration/guide/if_vPC.html#wp1558485
Jerry Ye
vPC is only available between 2 switches. If you have N7K, you can put them in different VDC, but not the N5K.
HTH,
jerry
