vPC Operational Layer3 Peer-router
zekebashi
Level 4
Level 4
I've configured vPC between two NX93180 and everything is working as expected. I enabled the peer-gateway feature as recommended by Cisco's documentation. The code on both switches is 7.0(3)I7(5a). When I issue the "show vpc" command, I see this parameter "Operational Layer3 Peer-Router" ---- "Disabled".  Can someone tell me why and should it show "Enabled"? If so, what command(s) do I need to get it enabled?
Thanks in advance,
~zK
Actually,  I've configured a separate L3 link between the two vPC switches in the vPC domain for routing and avoid using the vPC Peer-Link for routing.
That is fine.
I am not clear on when to enable Peer-Gateway and or Layer-3 peer-router if I am using a separate L3 link for routing between the two vPC switches with the domain. Can you please clarify?
You don't need "Layer-3 peer-router" command.  That applies to 7k with F2 and F3 cards.  see link:
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus7000/sw/interfaces/command/cisco_nexus7000_interfaces_command_ref/l_commands.html
6 Replies 6
Felipe A. Amaya
Layer 3 routing over vPC is configured under the vPC domain with that command, the peer-gateway is enabled when using this feature.
NX-#(config)#vpc domain 101
NX-#(config-vpc-domain)#layer3 peer-router
In our case we are using HSRP of an extended VLAN tied to HA'd firewalls, we have stablished OSPF between the Nexus peers and the Firewalls.  The VLAN is part of the Peer-links.
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/sw/nx-os/interfaces/configuration/guide/b-Cisco-Nexus-7000-Series-NX-OS-Interfaces-Configuration-Guide-Book/configuring-vpcs.html#concept_09E6B311898E444CA27CD73CCC2E5BED
I hope this helps....
Reza Sharifi
Operational Layer3 Peer-Router is a different command and has nothing to do with peer-gateway command.
As long as under "sh vpc" you see that the peer-gateway is "enabled" you are good to go.
Thanks in advance,
~zK
That is fine.
I see. So, I'll only need to enable the "layer3 peer-router" feature if I intend to use the vPC Peer-Link to support L3 routing. However, in my case, since I am using a separate L3 physical link for that purpose, then I don't need to enable this feature.
Thanks much, Reza!
Best, ~sK
layer3 peer-router
To enable support for layer 3 routing protocols over virtual port channels (vPCs), use the layer3 peer-router command. To disable support for layer 3 routing protocols, use the no form of this command.
layer3 peer-router
no layer3 peer-router
Thanks Reza, you are right I did not catch peer-gateway on the first comment.  Just to add to it, the way that I understand the vPC peer-gateway, the capability allows a vPC device to route packets that are addressed to the router MAC address of the vPC peer.
Thank you,
