04-24-2013 01:35 AM - edited 03-07-2019 01:00 PM
anyone know if "vpc-orphan-port suspend" works if i put on N2k interface. not the fex link.
example i have fex 101
and i put on eth 101/1/10
will it suspend the port on N2K connected to secondary N5K when peer link is down?
regards
04-24-2013 06:17 AM
Yes, but you need 5.2(1) or later version.
see below:
When a device that is not vPC-capable connects to each peer, the connected ports are known as orphan ports because they are not members of a vPC. Beginning with Cisco NX-OS Release 5.2(1), you can explicitly declare phyiscal interfaces as orphan ports to be suspended (shut down) by the secondary peer when it suspends its vPC ports in response to a peer link or peer-keepalive failure. The orphan ports are restored when the vPC is restored.
Here is the link:
04-28-2013 08:40 PM
h9i,
does it work on nexus 2000 port?
06-01-2018 12:42 AM
vpc orphan-ports suspend is only supported on physical interaces & not on port-channels.
To have this mentioned in the CCO doc, there is already a bug filed.
