03-19-2020 08:08 AM
Hello Cisco Community
I have a question regarding how should Exclude vlans from a VPC Peer-Link, Here's the issue
I got a peer-link between 2 VDC on a Nexus7k, I got VPC configured, but there's an issue that Vlans on one side doesnt match the same vlans in the other(Basically 2 vlans exist on A VDC that doesnt exist on B VDC) so I want to exclude those vlans from the VPC Peer link so vlans match.
Whats the best approach to do that? Should I permit all the vlans created on the Peer-Link Trunk(around 400)? or is there an easier way to do this?
Best Regards!
03-19-2020 08:12 AM
if the VLAN only belong to One of parent Switch, they can Prefer to be Locally available, they should required to be on peer-link.
Other Side Allowing Peer-link not going to harm. in the Future if you like to move around other switch, it easy move for you.
03-19-2020 08:49 AM
03-19-2020 08:59 AM
Best way to allow the VLAN in to Peer-link. and only allowed required VLAN allowed list towards Trunk.
Other question, where is this Trunk going to, is this connected to both vPC switches ? how is that other device conenced.
Can you also post that error to understand better.
03-19-2020 08:14 AM
a VPC peer link usually has all the vlans. So, try configuring it as just a trunk port.
