08-28-2018 05:08 PM - edited 03-08-2019 04:01 PM
So I have a setup of 2 9k as cores in a VPC domain and both VPC configs on each of these switches are configured with same priority 100, however one switch is the primary role and I would like it to be the other switch. Should I configure the other switch with a higher priority?
Also, connecting to these Core 9k are a couple more 92k as access switches in VPC domains as well. I want these in VPC as well because servers will be dual connected to be in Active Active mode with same priorites. Is this a good setup? Should I only do VPC at the access layer?
08-28-2018 05:39 PM
You can configure the other switch with higher priority but the VPC role will not switch until you reboot the current primary chassis or break the VPC connection between the 2 switches (sh and no sh on the VPC peer-link).
Yes, you can connect each access switch to both 9k core switches and build a vPC for each.
08-28-2018 05:50 PM
08-28-2018 06:02 PM
Ok so I did reboot one Core and now Core 2 is the primary VPC. To make Core 1 primary again I would have to reboot the secondary (Primary VPC)?
That is correct.
How is it done, do you usually just do a track object for interface to Primary core?
I am not sure what is this tracking for. What are you trying to do?
08-28-2018 06:15 PM
08-28-2018 06:18 PM
No need for that at all. Usually, both links to core switches are in a Portchannel and when one link goes down the other link continues to operate and forward traffic.
08-29-2018 10:06 AM
Ok good I did not feel like doing all that 🙂
So tracking to edge device from Cores should be good.
09-02-2018 12:06 PM
09-02-2018 12:37 PM
These 2 commands are global under the vpc domain
vpc domain x
peer-switch
09-02-2018 05:16 PM
