Single sided vs Double Sided VPC
CiscoBrownBelt
Level 11
Level 11
So in a topology where 2x 95k Nexus will be Core, and 4x 93k Nexus will be access, is it best to join the 2x 9504 in a VPC domain let's say VPC domain 10, then 1st pair of 93k as VPC Domain11, next pair VPC domain 12.
Just do all SVI on the cores, only 1 SVI for manangement on Access switches, then configure trunks between access and core switches if you only have 1 uplink?
8 Replies 8
nazimkha
Double Sided vPC would be a better approach.
I didnt understand where do you have 1 uplink from?
Access switches to Cores.
You need to have at least 2 links between two vPC domains to form a double sided vPC
So meaning each access layer switch must have 2x links to Core 1 and 2x links to Core 2? I am confused.
Something like this
So yes that is exactly how my lab is setup.
Should peer-switch and peer=gateway command not only be configured on the Core VPC switches but the Access VPC switches as well?
