VPC question
matthew.rogerson1
Community Member
Quick question.
The client I'm working for has a Nexus 3064-T switch, which will soon be end of life.
Is there a requirement that to create a VPC pair with another N3K switch, it has to be the same model, or would they be able to purchase, say, a Nexus 3048 and create a VPC peer between these 2 switches?
InayathUlla Sharieff
Yes you will be able to create the VPC between the same series of devices.
