04-16-2018 03:15 PM - edited 03-08-2019 02:40 PM
Hello, I have a vpc peer-keepalive with same priority but actually 10.111.5.2 in my example is primary. Having same role priority what can affect vpc role to be primary or secondary ?
vpc domain 10
role priority 100
peer-keepalive destination 10.111.5.2 source 10.111.5.1 vrf KeepAlive
delay restore 150
peer-gateway
auto-recovery
ip arp synchronize
interface Vlan1
no shutdown
vrf member KeepAlive
ip address 10.111.5.1/30
vPC Role status
vPC role : secondary
Dual Active Detection Status : 0
vPC system-mac : xx:xx:xx:xx:xx:xx
vPC system-priority : 32667
vPC local system-mac : xx:xx:xx:xx:xx:xx
vPC local role-priority : 100
vpc domain 10
role priority 100
peer-keepalive destination 10.111.5.1 source 10.111.5.2 vrf KeepAlive
delay restore 150
peer-gateway
auto-recovery
ip arp synchronize
interface Vlan1
no shutdown
ip address 10.111.5.2/30
vPC Role status
vPC role : primary
Solved! Go to Solution.
04-16-2018 05:50 PM
If the role priorities are equal, the system software uses the lowest mac address on the switch to select the primary device.
04-16-2018 04:34 PM
Whichever switch you want to be the primary should have a lower number. This way, it is always clear which switch is the primary.
primary
role priority 100
backup
role priority 200
04-16-2018 04:57 PM
Thanks Reza I see but I was wondering how it is established who is the primary with equal priority configured .. if it makes sense.
04-16-2018 05:50 PM
04-17-2018 05:41 AM
Thanks 🙂
09-24-2018 05:16 AM
09-25-2018 06:49 AM
