vPC with portfast or edge trunk
marouasa
Hello all,
Can we have portfast enabled in a vPC port that is facing a server or is it better to enable edge trunk on that port ?
Thanks for your feedback.
2 Accepted Solutions
 edge port in nsk is same as portfadt in other cisco SW.
You can use edge trunk for server sure
MHM
Pavel Tarakanov
MHM
Pavel Tarakanov
hello
Portfast edge trunk if  the pc is a trunk
Portfast edge if it the pc is an access
edited - just like to state be careful only enable portfast edge trunk to a trunk ONLY if you are sure it connecting to an edge device such as as server and not another switch
Kind Regards
Paul
Joseph W. Doherty
Whether to have a port flagged as a STP edge port is NOT directly related to it carrying a single VLAN or many.  They are different considerations.
This can be easily misunderstood because a single VLAN port is most commonly used for edge hosts while a multi VLAN port is commonly used with other switches.
