VPDN protocol ppoe on cisco 2811 iso
teymur azimov
Hi dears
I want to configurate Vpdn protocol PPOE but i can not write protocol  ppoe under vpdn group name on cisco 2811. cisco 2811 iso is 12.4 T advententerpr and i upgrade it 15.1 advansecure but problem is still. i think that problem is ios. which ios i must be upgrade??
please help .
thanks
5 Replies 5
atef yamin
Hi Teymour,
Under the new IOS's you dont need to use vpdn to support the pppoe clients. simply use enable command under the interface:
pppoe-client dial-poo-number
you should also look into bba-group configurations should you require more sessions.
thanks.
i understand that when i use 15.1 advansec ios i do not need vpdn i just write
pppoe-client dial-poo-number under the interface.
can you say me which old iso of  2811 is support pppoe protocol at vpdn?
i do not want to use bba-group.
thanks.
check this link,
this may give you some insight,, i believe 12.4(24)T has the option.
http://www.cisco.com/en/US/docs/ios/12_2t/12_2t15/feature/guide/ftpprfls.html
May be someone else can shed some more light too
HTP
thank you very much. i want to ask one question .
if i used new ios 15.1 advansec  must I be write this command?
vpdn enable
vpdn-group 1
request-dialin
or just as you wrote me only write this(pppoe-client dial-poo-number)
command under interface?
thanks you very much.
you will not need the vpdn-group or vpdn enable commands. You will simply use the interface pppoe-client dial pool command.
HTP
