VPN and Remote desktop configuration troubles
haa
Hi all,
so I got a cisco router 880, which I wanna configure to get access to its network via vpn , and also configuring remote desktop connection to one of the server in my LAN from home.
I tried a lot of combines, and i admit I m not that good with cisco NAT, ACL and PATS.
If anyone can help me figure the issue with my configuration below I would be gratefu:
Building configuration...
Current configuration : 2679 bytes
! Last configuration change at 16:16:38 UTC Tue Nov 28 2017
version 15.4
hostname mloc
boot-start-marker
boot-end-marker
enable password <removed>
aaa new-model
aaa authentication login userauthen local
aaa authorization network groupauthor local
aaa session-id common
ip domain name ***.com
ip cef
no ipv6 cef
license udi pid C881-K9 sn FCZ2102137X
username user password 0 <removed>
username cisco
crypto isakmp policy 3
encr 3des
authentication pre-share
group 2
crypto isakmp client configuration group vpnclient
key <removed>
dns 192.168.90.254
pool ippool
acl 101
crypto ipsec transform-set myset esp-3des esp-md5-hmac
mode tunnel
crypto dynamic-map dymap 10
set transform-set myset
reverse-route
crypto map clientmap client authentication list userauthen
crypto map clientmap isakmp authorization list groupauthor
crypto map clientmap client configuration address respond
crypto map clientmap 10 ipsec-isakmp dynamic dymap
interface FastEthernet0
switchport access vlan 100
no ip address
duplex full
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface FastEthernet4
description interface-wan
ip address 192.168.1.2 255.255.255.0
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface Vlan1
no ip address
interface Vlan100
description vlan-operationnel
ip address 192.168.90.254 255.255.255.0
ip nat inside
no ip virtual-reassembly in
ip local pool ippool 192.168.100.1 192.168.100.15
ip forward-protocol nd
ip http server
no ip http secure-server
ip nat source list 2 interface FastEthernet4 overload
ip nat inside source list 111 interface FastEthernet4 overload
ip nat inside source static tcp 192.168.90.2 3399 "PUBLIC IP" 3399 extendable
ip route 0.0.0.0 0.0.0.0 192.168.1.1
access-list 2 permit 192.168.90.0 0.0.0.255
access-list 101 permit ip 192.168.90.0 0.0.0.255 192.168.100.0 0.0.0.255
access-list 111 deny ip 192.168.90.0 0.0.0.255 192.168.100.0 0.0.0.255
access-list 111 permit ip any any
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
line con 0
no modem enable
line aux 0
line vty 0 4
transport input ssh
scheduler allocate 20000 1000
end
Thank you a lot !
0 Replies 0
