VPN Client and routing
paa
Hi!
I have a strange problem with VPN Client and routing.
[local-A]-[2811]-----[ISP]-----[PC-Win]-[local-B]
My PC with Windows connect from remote office to 2811 by VPN Client. So, from PC I can access local-A behind 2811 and local-B. This PC is a default gw for local-B network.
So, I have a problem - other PCs in local-B networ cann't access PCs in local-A. On Windows router (local-B) I see a route to local-A through VPN, but it's not work! Also I try to add route on 2811 to local-B through 10.0.0.1 (it is ip-address of my VPN-client connection) but it not helped
My config (only main part):
local-A -- 192.168.0.0/24
local-B -- 192.168.1.0/24
crypto isakmp client configuration group test
key test_12_vpn
pool VPN-CLIENT
acl VPN-ACL
crypto dynamic-map vpn_dn_map 10
set transform-set TRANS
reverse-route
crypto map VPN 5 ipsec-isakmp dynamic vpn_dn_map
ip local pool VPN-CLIENT 10.0.0.1
ip route 192.168.1.0 255.255.255.0 10.0.0.1
ip access-list extended VPN-ACL
permit ip 192.168.0.0 0.0.0.255 host 10.0.0.1
permit ip 192.168.0.0 0.0.0.255 192.168.1.0 0.0.0.255
owillins
Level 6
Level 6
Please use this Configuration guide for your VPN configuration.
http://www.cisco.com/en/US/products/ps5854/tsd_products_support_configure.html
