12-13-2014 10:58 AM - edited 03-07-2019 09:53 PM
hi all
i configure IPsec VPN on cisco CSR 1000V and i connect to the VPN router by cisco vpn client
every thing is good bu when i start view the DVR camera streaming after 10 sec i lost the connection to the DVR and, but still have access to all he remote network and i can transfer files
so there is any thing i do on cisco CSR to solve the streaming failure
thanks
Solved! Go to Solution.
12-14-2014 08:34 AM
Does the DVR streaming work fine when you are locally connected to the LAN?
Take a look at the DVR setting. There maybe some sort of setting you can change and test.
12-14-2014 08:34 AM
12-14-2014 12:34 PM
hi
yes the DVR streaming work fine when i locally connected to the LAN
the problems solved
it was loop in my network
thanks
12-14-2014 01:26 PM
Great, thanks for the update and the rating.
Reza
