VRF - Import Map Not Working - Nexus 9k
Hello Everyone,
I am trying to filtering in VRF using import map on nexus 9000 switch. First i tried on catalyst switch and it worked perfectly but same concept not working on nexus. NX-OS version is 7.2
In switch two VRF's are created GEN_SERVER & IPT_SERVER. i am doing import and export using rt between this vrf.
But IPT_SERVER VRF has two subnet but i want to import only 1 subnet into GEN_SERVERS VRF. Below config is not working for this purpose.
vrf context GEN_SERVERS
address-family ipv4 unicast
import map GEN_SRV
route-map GEN_SRV permit 10
match ip address 10
ip access-list 10
10 deny ip 10.18.244.0/24 10.18.190.0/24
20 deny ip 10.18.190.0/24 10.18.244.0/24
30 permit ip any any
Below is full configuration for two VRF's
rd 65111:212
route-target import 65111:201
route-target import 65111:212
route-target export 65111:212
import map GEN_SRV
vrf context IPT_SERVERS
rd 65111:201
route-target export 65111:201
vlan 30
vlan 990
vlan 983
interface Vlan30
no shutdown
vrf member IPT_SERVERS
ip address 192.168.30.251/24
ip router ospf 1 area 0.0.0.0
hsrp version 2
hsrp 30
preempt
priority 110
ip 192.168.30.254
interface Vlan983
no shutdown
no ip redirects
ip address 10.18.244.251/24
hsrp version 2
hsrp 983
preempt
priority 110
ip 10.18.244.254
interface Vlan990
no shutdown
vrf member GEN_SERVERS
no ip redirects
ip address 10.18.190.251/24
hsrp version 2
hsrp 990
preempt
priority 110
ip 10.18.190.254
router bgp 1
vrf GEN_SERVERS
redistribute direct route-map vpn-route-leaking
vrf IPT_SERVERS
show version output
Software
BIOS: version 07.45
NXOS: version 7.0(3)I4(2)
BIOS compile time: 12/04/2015
NXOS image file is: bootflash:///nxos.7.0.3.I4.2.bin
NXOS compile time: 7/21/2016 8:00:00 [07/21/2016 16:09:32]
Kindly advise what could be the problem with this
Any advise for the above from experts Please.
