VRF issue
adergah
Hello everyone,
I have a problem due to VRF issue. If anyone can find me a solution I would appreciate it. I am sending my current configuration in brief to check:
vrf definition PENS_MSG_OPS
 rd 2:2
 route-target export 2:2
 route-target import 2:2
 address-family ipv4
 exit-address-family
 address-family ipv6
 exit-address-family
vrf definition PENS_MSG_TEST
 rd 3:3
 route-target export 3:3
 route-target import 3:3
 address-family ipv4
 exit-address-family
 address-family ipv6
 exit-address-family
interface Loopback2
 vrf forwarding PENS_MSG_OPS
 ip address 57.235.248.67 255.255.255.255
interface Loopback3
 vrf forwarding PENS_MSG_TEST
 ip address 57.235.248.70 255.255.255.255
interface GigabitEthernet0/0/0
 description to_DHMI_BACKUP_ROUTER
 ip address 10.26.1.1 255.255.255.252
 no ip proxy-arp
 negotiation auto
interface GigabitEthernet0/0/1
 description to_DHMI_LAN
 no ip address
 negotiation auto
interface GigabitEthernet0/0/1.2
 description PENS_MSG_OPS
 encapsulation dot1Q 2
 ip address 57.235.205.177 255.255.255.240
 standby version 2
 standby 102 priority 255
 standby 102 preempt delay minimum 20
 standby 102 authentication md5 key-string 7dhmi
 service-policy input input_match
interface GigabitEthernet0/0/1.3
 description PENS_MSG_TEST
 encapsulation dot1Q 3
 ip address 57.235.205.201 255.255.255.248
 standby version 2
 standby 152 priority 255
 standby 152 preempt delay minimum 20
 standby 152 authentication md5 key-string 7dhmi
interface GigabitEthernet0/1/0
 switchport access vlan 102
 switchport trunk allowed vlan 102
 switchport mode trunk
interface GigabitEthernet0/1/1
 switchport access vlan 152
 switchport trunk allowed vlan 152
interface Vlan102
 ip address 57.235.239.210 255.255.255.252
 no ip proxy-arp
interface Vlan152
 ip address 57.235.239.222 255.255.255.252
 no ip proxy-arp
router bgp 64784
 bgp router-id 57.235.239.210
 bgp log-neighbor-changes
 no bgp default ipv4-unicast
 timers bgp 15 45
 neighbor 10.26.1.2 remote-as 64784
 address-family ipv4
  neighbor 10.26.1.2 activate
  neighbor 10.26.1.2 send-community extended
  neighbor 10.26.1.2 next-hop-self
 exit-address-family
 address-family ipv4 vrf PENS_MSG_OPS
  network 57.235.205.176 mask 255.255.255.240
  neighbor 57.235.239.209 remote-as 65000
  neighbor 57.235.239.209 description OPS_MSG_VPN
  neighbor 57.235.239.209 activate
  neighbor 57.235.239.209 send-community extended
  neighbor 57.235.239.209 prefix-list DHMI out
  neighbor 57.235.239.209 route-map set_metric_50 out
 exit-address-family
 address-family ipv4 vrf PENS_MSG_TEST
  bgp router-id 57.235.239.222
  network 57.235.205.200 mask 255.255.255.248
  neighbor 57.235.239.221 remote-as 65000
  neighbor 57.235.239.221 description MSG_TEST
  neighbor 57.235.239.221 activate
  neighbor 57.235.239.221 send-community extended
  neighbor 57.235.239.221 prefix-list DHMI out
  neighbor 57.235.239.221 route-map set_metric_50 out
 exit-address-family
ip forward-protocol nd
no ip http server
no ip http secure-server
ip tftp source-interface GigabitEthernet0
ip as-path access-list 1 permit ^$
ip access-list extended qos_D1
 permit tcp any any eq 8500
 permit tcp any eq 8500 any
 permit udp any any eq 8500
 permit udp any eq 8500 any
ip access-list extended qos_D2
 permit tcp any any eq 102
 permit tcp any eq 102 any
 permit udp any any eq 102
 permit udp any eq 102 any
ip access-list extended qos_D3
 permit ip any any
ip prefix-list DHMI seq 10 permit 57.235.205.176/28
ip prefix-list DHMI seq 20 permit 57.235.205.200/29
route-map set_metric_50 permit 10
 set metric 50
So here is the explanation:
My gig 0/1/0 and gig 0/1/1 ports are connected to PE router and I am configuring the CE router. There is no problem on bgp I can ping vrf to the Interface of PE routers. What the problem is on my 0/0/1 port it will be connected to my local Lan. IP routes will further be added but what I am trying to do is I am giving my computer as the IP of 57.235.205.181/28 for example and I can ping the Routers interface of Gig 0/0/1.2 which is 57.235.205.177. However on the Router I can't ping to the address of computer. What is more surprising is I can't even ping to the it's own IP address on the router itself. When I remove the command Vrf forwarding PENS_MSG_OPS from subinterface 0/0/1.2 for example this time I can ping the computer but I can't ping the IP VRF on the PE router side from my router. What am I missing here? what kind of change should I make to ping both of them? If you can help me I will appreciate it. Thank you for your helps, have a nice weekend.
25 Replies 25
does the original post have the full configuration of the router ? Take all the unused and incomplete parts out. Is there anything else left in the service policy ?
this is the all configuration I have:
Building configuration...
Current configuration : 5553 bytes
! Last configuration change at 15:31:23 UTC Sat Dec 16 2017
version 15.5
no platform punt-keepalive disable-kernel-core
hostname DHMI_PENS_PRIMARY
boot-start-marker
boot-end-marker
vrf definition Mgmt-intf
 address-family ipv4
 exit-address-family
 address-family ipv6
 exit-address-family
 rd 2:2
 address-family ipv4
 exit-address-family
 address-family ipv6
 exit-address-family
 rd 3:3
 address-family ipv4
 exit-address-family
 address-family ipv6
 exit-address-family
enable password network
no aaa new-model
ip vrf forwarding
subscriber templating
license udi pid ISR4331/K9 sn FDO21081CAT
redundancy
 mode none
vlan internal allocation policy ascending
class-map match-any D1
  description FMTP
 match access-group name qos_D1
class-map match-any D2
  description AMHS
 match access-group name qos_D2
class-map match-any D3
 match any
policy-map input_match
 class D1
 class D2
 class D3
interface Loopback2
interface Loopback3
 ip address 57.235.248.68 255.255.255.255
interface Loopback102
 shutdown
interface Loopback152
 shutdown
 no ip proxy-arp
 negotiation auto
 no ip address
 negotiation auto
 standby version 2
 standby 102 ip 57.235.205.178
 standby version 2
 standby 102 ip 57.235.205.202
interface GigabitEthernet0/0/2
 no ip address
 shutdown
 negotiation auto
interface GigabitEthernet0/1/2
 switchport access vlan 2
 shutdown
interface GigabitEthernet0/1/3
 switchport access vlan 3
 shutdown
interface GigabitEthernet0/1/4
interface GigabitEthernet0/1/5
interface GigabitEthernet0/1/6
interface GigabitEthernet0/1/7
 vrf forwarding Mgmt-intf
 no ip address
 shutdown
 negotiation auto
interface Vlan1
 no ip address
 shutdown
interface Vlan102
 no ip proxy-arp
interface Vlan152
 no ip proxy-arp
router bgp 64784
 timers bgp 15 45
 address-family ipv4
 exit-address-family
 exit-address-family
 exit-address-family
no ip http server
 permit ip any any
 set metric 50
control-plane
line con 0
 stopbits 1
line aux 0
 stopbits 1
line vty 0 4
 password network
 login
end
the classes in your service policy do not have any action defined.
Take the entire service policy off the interface, also the HSRP stuff, so it should look like this:
HSRP does work because I have a standby router as you can see in the configuration. And I don't see any relation between service policy and not being able to ping the computer. Thank you for your helps.
mattjones03
It does sound like it’s a case of your Windows firewall being enabled.
With the Windows firewall temporarily disabled, does this correct the issue?
It is definetely not firewall problem of Windows. I tried 3 different computers one with Linux. And it didn't work.
can you ping with the HSRP standby address, 57.235.205.178, as the source ?
ping vrf PENS_MSG_OPS 57.235.205.181 source 57.235.205.178 ?
And vice versa, can your PC/computer ping 57.235.205.178 Your PC/computer needs to have 57.235.205.178 as the default gateway, make sure that is configured...
I am off at the work for today. Tomorrow night I will be able to do these steps and I will inform you about the results. Thank you for your helps and supports. Have a good weekend.
So here is the last situation:
Right now I can ping vrf 57.235.205.181 from the router,
I can ping 57.235.205.177 and standby address 57.235.205.178 from the computer.
Just I can't ping 57.235.205.181 without vrf from the router.
Is this a normal situation in my case?
--> I can't ping 57.235.205.181 without vrf from the router.
That is the to-be-expected behaviour. The entire subnet is part of the VRF, so only reachable within the VRF.
Problem seems to be solved. Thank you very much for your helps and supports.
Best regards,
