VRF NAT Translation / Port Translation
Jeffrey Simon
I recently moved the subnet 10.0.50.0/24 into a VRF.  After doing so I realized this broke one of my NAT translations:
ip nat inside source static tcp 10.0.50.230 22 interface GigabitEthernet1/1 9022
I located the following document: http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/ipaddr_nat/configuration/xe-3s/nat-xe-3s-book/iadnat-match-vrf.pdf
It shows different types of NAT translations for VRF's, but not what I am looking to do exactly.  Can someone assist me in getting the above NAT translation to work with a host that is in a VRF?
Thanks!
Hello
As I stated previously "need to specify a static inside global address instead of the interface"
example:
ip nat inside source static tcp 10.0.50.230 22 192.168.100.100 9022 vrf EXAMPLE
res
Paul
Kind Regards
Paul
10 Replies 10
Hello
When using static NAT & VRF,  I think you need to specify a static inside global address instead of the interface to use the vrf option
ip nat inside source static tcp 10.0.50.230 22 x.x.x.x 9022 vrf XX
res
Paul
Kind Regards
Paul
Does not appear to be supported:
cda6503a(config)#ip nat inside source static tcp 10.0.50.230 22 interface gigabitEthernet 1/1 9022 ?
  <cr>
Hello
example:
res
Paul
Kind Regards
Paul
Thank you, I did not understand what you were saying.  This is working now.  Thank you very much for the help.
As you stated previously: "need to specify a static inside global address instead of the interface".
However, what if the inside global address is obtained through DHCP and may rarely change?
I am facing this exact case. I need to refer to the interface to cope with the IP that might change, but then, I can not use the VRF nor the extendable statement.
Would you be aware of a solution in that case?
Kind regards,
Cedric.
Hello
You could try an access-list with a route-map
Example:
access-list 100 permit tcp host x.x.x.x any eq 443
route-map RM-ACL
match ip address 100
match interface <wan interface>
ip nat inside source route-map RM_ACL interface <wan interface> vrf EXAMPLE
Kind Regards
Paul
I'm trying your proposition but I don't understand how to specify the ports in your example.
If we take the original post:
10.0.50.230 will be our interface <wan interface>.
How to forward the port 22 of the <wan interface> to the port 9022 of the station 192.168.100.100 with the route map?
Hello
Probably need to lab this one up, Not sure you can do this without specifying the host ip address, Thinking of utilizing a nat statement with a route-map and acl pointing to the vrf wan interface but again not confident it will work.
Kind Regards
Paul
Hello again,
I have the situation in lab and I can try it directly.
So (I adapted all values to the example given):
does work, it forwards port 9022 of 192.168.100.100 (<wan interface>) on machine 10.0.50.230 port 22 which lies in vrf EXAMPLE.
What I does not exactly understand is how to transform that into an access-list with a route-map as you proposed.
I did:
access-list 100 permit tcp host 10.0.50.230 eq 22 any eq 9022
route-map RM-ACL
ip nat inside source route-map RM-ACL interface <wan interface> vrf EXAMPLE
Which does not work. What do you think of it?
Best regards,
Cedric.
Hello again,
I have another question.
When 10.0.50.0/24 is moved into VRF example, we have to transform:
to:
With 192.168.100.100 being the address of the interface GigabitEthernet1/1.
Moving from the interface to the IP allows to use the vrf statement.
However, if the ip address of GigabitEthernet1/1 is dynamic and may change (obtained through DHCP for example), we cannot use the IP.
Therefore, would it not be possible to use the first command:
And set up a leaking between the VRF where lies the interface GigabitEthernet1/1 and the VRF EXAMPLE?
If I understand well, from outside to inside, translation of address is performed before routing, then, the packet arriving with destination 192.168.100.100 port 9022 would first be converted to have a destination 10.0.50.230 with port 22. Then, inside the VRF of GigabitEthernet1/1, the route leak shall permit to transfer it to VRF EXAMPLE.
Is such a construction possible?
Best regards,
Cedric T.
