VRF understanding?
srikanth ath
Level 4
Level 4
    Hello Experts,
Im  a new bee to VRF. I have gone through some articles and could understand that you are virtualising a single router into many based on the VRF's defined.
I have a scenario where i want to understand how VRF routing table is Linked to Global routing table.
ip vrf INTERNET
rd 56211:10
interface GigabitEthernet6/46
  no switchport
ip vrf forwarding INTERNET
ip address 10.10.10.1 255.255.255.252
Interface Vlan 101
ip addres 10.10.20.1 255.255.255.252
Interface Vlan 201
ip addres 10.10.30.1 255.255.255.252
Default route to access the internet ::
ip route 0.0.0.0 0.0.0.0 10.10.1.1  1
By above default route whether vlan 101 will be able to access internet?  If Yes, how vlan101 would be able to access internet as we brought the vlan under seperate VRF INTERNET. If no, what should be done keeping VRF config same making vlan 101 access internet.
Appreciate your quick response.
Thanks a lot
Sreekan th
cadet alain
No it won't work this way, you have to do VRF leaking with the global routing table.
This is explained here:http://blog.ipexpert.com/2010/12/01/vrf-route-leaking/
Alain
cadet alain
Alain
Another query alain
1.  what is the  Difference between VRF and VRF lite with an config example & functioning will help me a lot .
This is out of the subject. but postin here.
2.  We have arround 10 sites connected with MPLS together to HUB site and every site Wan router is configured with DMVPN tunnel and inturn every site Core switch is  configured as GRE tunnel to HUB core switch. can i know whats the purpose of the GRE tunnel as we already have DMVPN. Note: we are running OSPF as dynamic routing protocl for all of the sites.
Srikanth
VRF Lite is VRF without MP-BGP so it is basically what you had, VRF is also used for MPLS VPN and then it is run along MP-BGP.
DMVPN is using GRE tunnels whether point-to-point or multipoint tunnels depending upon the DMVPN phase and if you want spoke-to-spoke connectivity without using the HUB.
Alain
