11-07-2022 04:08 AM
Hi everyone,
I have two switches. one 9200 and another 9300.
I want to configure VRP between them, but the vrrp commands do not appear on vlan interface configuration.
I've checked and I need to execute a command "fhrp version vrrp v3" first into the devices.
I'd like to know if this command has any impact in my environment?
Today I have some vlans working in production.
First, I would like to test the VRRP in a separated vlan and after this, I will move my productions vlans to VRRP.
Thanks all.
Solved! Go to Solution.
11-07-2022 04:27 AM
If you do not have any VRRPv2 config, you ok to do that command :
When VRRPv3 is in use, VRRPv2 is unavailable. For VRRPv3 to be configurable, the fhrp version vrrp v3 command must be used in global configuration mode
11-07-2022 04:27 AM
11-07-2022 04:39 AM
fhrp version vrrp v3 <<-
is enable VRRP v3 which different than v2 in support IPv6.
so by default V2 is run and support IPv4.
so can you more elaborate what command can not enter ?
11-07-2022 04:39 AM
Thank you very much.
I've already tested and is working as expected.
