VRRP Help Part Deux
visitor68
Level 5
Level 5
I created a new thread because the other one has sort of been closed by the fact that I marked some answers as having resolved the issue (red check mark), so i think no one is going to open the thread.
Jon or anyone else, of course:
Here is the final configuration for VRRP that the engineer says he finally got to work.
Now, this makes more sense than the really weird stuff I have been posting from him.
But something is still wrong. Notice the duplicate IP addresses on the actual vlan interfaces and the fact that the vrrp VIPs are different. Also notice the output of the 'sho vrrp br' comand on router 3.
This is all normally straightforward to me. VRRP is almost exactly like HSRP with some minor differences, but the configuration is almost identical in its execution and logic.
I do know that VRRP does allow you to configure one of the routers with the VIP address (router interface and VIP are the same)- and in the event of a failure, the standby takes over that address. Its a feature you can use, but it doesnt apply to what this engineer has configured here anyway.
7609-4#sh run
interface Vlan11
ip address 71.22.16.2 255.255.252.0
vrrp 1 ip 71.23.64.3
vrrp 2 ip 71.22.16.3
interface Vlan21
ip address 10.36.144.2 255.255.255.0
vrrp 3 ip 10.36.144.3
interface Vlan22
ip address 10.36.145.2 255.255.255.0
vrrp 4 ip 10.36.145.3
interface Vlan23
ip address 10.36.146.2 255.255.255.0
shutdown
vrrp 5 ip 10.36.146.3
7609-3#sh run
interface Vlan11
vrrp 1 ip 71.23.64.1
vrrp 1 priority 200
vrrp 2 ip 71.22.16.1
vrrp 2 priority 200
interface Vlan21
vrrp 3 ip 10.36.144.1
vrrp 3 priority 200
interface Vlan22
vrrp 4 ip 10.36.145.1
vrrp 4 priority 200
interface Vlan23
vrrp 5 ip 10.36.146.1
vrrp 5 priority 200
NC-CLT1-7609-3#sh vrrp brief
Interface Grp Pri Time Own Pre State Master addr Group addr
Vl11 1 200 3218 Y Init 0.0.0.0 71.23.64.1
Vl11 2 200 3218 Y Init 0.0.0.0 71.22.16.1
Vl21 3 200 3218 Y Init 0.0.0.0 10.36.144.1
Vl22 4 200 3218 Y Init 0.0.0.0 10.36.145.1
Vl23 5 200 3218 Y Init 0.0.0.0 10.36.146.1
5 Replies 5
Joe,
I'm a bit confused on your configuration. You assigned the same ip address on the physical interface on both devices. I want to know when using a "show vrrp" command what router says about Master router's ip address . And you configured VIP with different IP address on the same group. D'oh!!![Pretending to be Simpson](grin)
What about this kind of configuration?
7609-4#sh run
interface Vlan11
ip address 71.22.16.1 255.255.252.0
ip address 71.23.64.1 255.255.255.0 secondary
vrrp 1 ip 71.22.16.3
vrrp 2 ip 71.23.64.3
7609-3#sh run
interface Vlan11
ip address 71.23.64.2 255.255.255.0 secondary
vrrp 1 priority 200
vrrp 2 priority 200
Please check out this link: http://www.cisco.com/en/US/docs/ios/12_0st/12_0st18/feature/guide/st_vrrpx.html#wp1036615
HTH,
Toshi
Giuseppe Larosa
Hello Joe,
there is something still not working.
Here it is the link to sh vrrp in command reference
http://www.cisco.com/en/US/docs/ios/ipapp/command/reference/iap_s2.html#wp1077496
we see that master address is 0.0.0.0 and state is stucked to Init.
This happens also for the VRRP groups where the VIP address belongs to the IP subnet on the interface.
I'm afraid that VRRP is designed to have the VIP address identical to the interface ip address of one of the routers.
Probably all routers are waiting for the master device to start to send advertisements so they are stucked in init state.
see
http://www.cisco.com/en/US/docs/ios/ipapp/configuration/guide/ipapp_vrrp_ps6350_TSD_Products_Configuration_Guide_Chapter.html#wp1054602
We should look at VRRP RFC to be sure of this
http://www.faqs.org/rfcs/rfc3768.html
It says:
The only exception is that a VRRP router will
always become Master of any virtual router associated with addresses
it owns.
Hope to help
Giuseppe
Hi, Toshi
I dont think you understand. I did not create these configurations. One of my engineers did and I am questioning its correctness, which is precisely why I posted here. The comments you make are also the ones I make in the introductory paragraph of this thread.
Joe,
Sorry I missed reading you didn't configure that. Configuration should not be like that. Time to fix it.
Toshi
Giuseppe:
I am in total agreement with what you and Toshi are saying. I know this configuration is wrong nd I know whats wrong with it.
So why did I post it here? I just wanted other opinions before I approach my engineer so as to avoid any embarrassing situation for him. I just wanted to be 100% sure, since I usually do not configure VRRP, but normally use HSRP.
