VRRP problem - state change
vitalykovalenko
Community Member
Hi. we have 2 cisco 2821 routers. Few days ago one of them (vrrp backup) started to change vrrp state from backup to master. Its trying to change status a few times and leave it as master. And now we have 2 masters. And this second router constantly trying to change vrrp status.
connection present on both routers.
Interesting but first router which working without problems, dont have any log messages about vrrp state change.
Here is the log file of "bad" router:
000087: May 27 18:25:49.346 EEST: %VRRP-6-STATECHANGE: Vl1 Grp 1 state Master -> Backup
000088: May 27 18:25:52.995 EEST: %VRRP-6-STATECHANGE: Vl1 Grp 1 state Backup -> Master
000089: May 27 18:27:38.149 EEST: %VRRP-6-STATECHANGE: Vl1 Grp 1 state Master -> Backup
000090: May 27 18:27:41.797 EEST: %VRRP-6-STATECHANGE: Vl1 Grp 1 state Backup -> Master
000091: May 27 18:29:30.767 EEST: %VRRP-6-STATECHANGE: Vl1 Grp 1 state Master -> Backup
000092: May 27 18:29:34.415 EEST: %VRRP-6-STATECHANGE: Vl1 Grp 1 state Backup -> Master
000094: May 27 18:31:14.153 EEST: %VRRP-6-STATECHANGE: Vl1 Grp 1 state Master -> Backup
000097: May 27 18:31:17.801 EEST: %VRRP-6-STATECHANGE: Vl1 Grp 1 state Backup -> Master
000098: May 27 18:32:41.423 EEST: %VRRP-6-STATECHANGE: Vl1 Grp 1 state Master -> Backup
000099: May 27 18:32:45.071 EEST: %VRRP-6-STATECHANGE: Vl1 Grp 1 state Backup -> Master
000101: May 27 18:34:25.557 EEST: %VRRP-6-STATECHANGE: Vl1 Grp 1 state Master -> Backup
000102: May 27 18:34:29.205 EEST: %VRRP-6-STATECHANGE: Vl1 Grp 1 state Backup -> Master
000103: May 27 18:36:06.403 EEST: %VRRP-6-STATECHANGE: Vl1 Grp 1 state Master -> Backup
000104: May 27 18:36:10.051 EEST: %VRRP-6-STATECHANGE: Vl1 Grp 1 state Backup -> Master
6 Replies 6
Peter010101
Level 4
Level 4
Are there any other messages in the logs?
Check the routers's cpu to see if it is running high.
no other messages, except vrrp and acl messages.
Cpu utilization ~0 %
"Bad" router
interface Vlan1
description Internal
ip address xxx.xxx.xxx.xxx xxx.xxx.xxx.xxx
ip access-group 102 in
no ip redirects
no ip unreachables
no ip proxy-arp
vrrp 1 ip xxx.xxx.xxx.1
vrrp 1 priority 90
no mop enabled
Working router
the same without vrrp 1 priority. it means, that it has priority 100 by default.
please help someone.
Compare the results from show vrrp on each device. It might be that the two devices are not seeing each other or are not communicating with each other.
this link should give you some more vrrp commands.
http://www.cisco.com/en/US/docs/ios/12_0st/12_0st18/feature/guide/st_vrrpx.html#wp1025628
hth
Jun 11 09:00:10 36687: 036692: Jun 11 09:00:10.413 EEST: VRRP: Grp 1 sending Advertisement checksum 5220
Jun 11 09:00:12 36688: 036693: Jun 11 09:00:11.353 EEST: VRRP: Grp 1 sending Advertisement checksum 5220
Jun 11 09:00:12 36689: 036694: Jun 11 09:00:12.257 EEST: VRRP: Grp 1 sending Advertisement checksum 5220
Jun 11 09:00:13 36690: 036695: Jun 11 09:00:13.065 EEST: VRRP: Grp 1 sending Advertisement checksum 5220
Jun 11 09:00:13 36691: 036696: Jun 11 09:00:13.121 EEST: VRRP: Grp 1 Advertisement priority 100,ipaddr 192.2.1.1
Jun 11 09:00:13 36692: 036697: Jun 11 09:00:13.121 EEST: VRRP: Grp 1 Event - Advert higher or equal priority
Jun 11 09:00:14 36693: 036698: Jun 11 09:00:13.121 EEST: %VRRP-6-STATECHANGE: Vl1 Grp 1 state Master -> Backup
Jun 11 09:00:16 36694: 036699: Jun 11 09:00:16.769 EEST: VRRP: Grp 1 Event - Master down timer expired
Jun 11 09:00:16 36695: 036700: Jun 11 09:00:16.769 EEST: %VRRP-6-STATECHANGE: Vl1 Grp 1 state Backup -> Master
Jun 11 09:00:17 36696: 036701: Jun 11 09:00:16.769 EEST: VRRP: tbridge_smf_update failed
Cant to find info about errors.
This is a physical layer problem. You need to make sure of the connectivity at layer 2 for this specific vlan. It seems to me that the link passing this vlan is flapping. Try passing this vlan on another link and block it from the current link, or if possible, change the link between both switches altogether.
BR,
Khaled Wahba
