VRRP supported switch with 9+1
sanjay-1190
I need to setup one network with VRRP Active-Active for High Availability, hence I have selected the following switches
WS-C3560X-24T-S                  x1 (Core)
WS-C2960X-24TS-L                x9 (Edge)
I am doubtful whether this selected switch will support Full VRRP or not,
Kindly Advice
Sanjay Kumar
  1. What do you mean with "Full" VRRP?
  2. How do you want to achieve active/active HA with only one core-switch?
I will deploy two L3 switches at the core location for VRRP, does the above switch supports VRRP or I need to buy any license etc, this is an IP base IOS Image switch
Ok, that will work. VRRP is supported on IPBase for the 3560-X. If there are no non-cisco devices in your core-layer, then you can also look at HSRP which is a little more flexible (if you need that).
Thank You :), will start deploying
