03-18-2019 01:27 AM
Good day, comrades. There is a configuration shown below and there is a problem with port-channel balancing (LACP). LACP is well assembled, it handles emergency situations, but sends traffic from 6509 to N5k using only one link, while N5k sends traffic to all active links. Any ideas on this issue or is this the expected behavior of VSS?
6509_VSS:
c6509_2_Mol9#sh etherchannel summary 30 Po30(SU) LACP Te1/1/13(P) Te2/1/1(P) c6509_2_Mol9#sh int po30 etherchannel Port-channel30 (Primary aggregator) Age of the Port-channel = 10d:11h:28m:14s Logical slot/port = 46/5 Number of ports = 2 HotStandBy port = null Port state = Port-channel Ag-Inuse Protocol = LACP Port security = Disabled Fast-switchover = disabled Fast-switchover Dampening = disabled Load share deferral = disabled Is fex host PO = FALSE Ports in the Port-channel: Index Load Port EC state No of bits ------+------+------------+------------------+----------- 1 FF Te1/1/14 Active 8 0 FF Te2/1/1 Active 8 c6509_2_Mol9#sh run int po30 interface Port-channel30 description to_N5k switchport switchport mode trunk switchport trunk allowed vlan 15,22,33,54,101,103,110,310,350-354,790,791,813 switchport trunk allowed vlan add 814,820-822,825-828 end c6509_2_Mol9#sh run int Te1/1/14 interface TenGigabitEthernet1/1/14 description to_N5k switchport switchport mode trunk switchport trunk allowed vlan 15,22,33,54,101,103,110,310,350-354,790,791,813 switchport trunk allowed vlan add 814,820-822,825-828 channel-group 30 mode active end c6509_2_Mol9#sh run int Te2/1/1 description to_N5k switchport switchport mode trunk switchport trunk allowed vlan 15,22,33,54,101,103,110,310,350-354,790,791,813 switchport trunk allowed vlan add 814,820-822,825-828 channel-group 30 mode active end
With the same settings, but on the interfaces of one line card:
c6509_2_Mol9#sh int po30 etherchannel Port-channel30 (Primary aggregator) Age of the Port-channel = 10d:11h:28m:49s Logical slot/port = 46/5 Number of ports = 2 HotStandBy port = null Port state = Port-channel Ag-Inuse Protocol = LACP Port security = Disabled Fast-switchover = disabled Fast-switchover Dampening = disabled Load share deferral = disabled Is fex host PO = FALSE Ports in the Port-channel: Index Load Port EC state No of bits ------+------+------------+------------------+----------- 0 53 Te1/1/13 Active 4 1 AC Te1/1/14 Active 4 Time since last port bundled: 0d:00h:00m:01s Te1/1/13 Time since last port Un-bundled: 0d:00h:00m:20s Te2/1/1
N5k_1/2:
N5kML9_1.1_3_1# sh port-c su 30 Po30(SU) Eth LACP Eth1/1(P) N5kML9_1.1_3_1# sh run int po30 interface port-channel30 description To_C6500 switchport mode trunk switchport trunk allowed vlan 15,22,33,54,101,103,110,310,350-354,790-791,813-814,820-822,825-828,1999 spanning-tree bpdufilter enable vpc 30 N5kML9_1.1_3_1# sh run int et1/1 interface Ethernet1/1 description To_C6500 switchport mode trunk switchport trunk allowed vlan 15,22,33,54,101,103,110,310,350-354,790-791,813-814,820-822,825-828,1999 channel-group 30 mode active
Solved! Go to Solution.
03-18-2019 02:42 AM
Ah OK. I see your problem.
On a 6500 in VSS, last time I checked if a port-channel has member links in both chassis, traffic would always leave via the local link and not traverse the VSL link in order to correctly load-balance the traffic.
This must be a symptom of how your VSS pair are connected to the rest of the network. One chassis is routing most of the traffic for those trunk link VLANs and is therefore using just is local port-channel link.
cheers,
Seb.
03-18-2019 01:43 AM
Hi there,
Sounds like either end of the port-channel might be using different hashing alogorithms. What is the output of:
on the 6509: show etherch load-bal
on the nexus: show port-channel load-balance
Also it is worth considering the type of traffic passing over this link and tuning the hash algorithm it suit. Which of the two devices does the routing for the bulk of these VLANs?
cheers,
Seb.
03-18-2019 01:55 AM
At the moment, the balancing is set like this, but I know that it’s not quite right. Yes, and changed the methods of balancing, it does not change the situation.
6500:
c6509_2_Mol9#sh etherch load
EtherChannel Load-Balancing Configuration:
src-dst-ip enhanced
mpls label-ip
EtherChannel Load-Balancing Addresses Used Per-Protocol:
Non-IP: Source XOR Destination MAC address
IPv4: Source XOR Destination IP address
IPv6: Source XOR Destination IP address
MPLS: Label or IPN5k:
N5kML9_1.1_3_1# sh port-c load-balance Port Channel Load-Balancing Configuration: System: source-dest-ip Port Channel Load-Balancing Addresses Used Per-Protocol: Non-IP: source-dest-mac IP: source-dest-ip source-dest-mac
Most of the vlans are routed from the 6500 side.
Nevertheless, I do not understand the method of calculating RBH for interfaces on different VSS switches, because for interfaces within one switch everything is considered correct.
03-18-2019 02:42 AM
cheers,
Seb.
