VSS auto-recovery feature?
fly
Level 2
Level 2
cisco 65 VSS
Can I  config auto-recovery feature like VPC if active switch goes into recovery mode?
I haven't found this feature on 65 VSS.
thank you
Tom
vb10
Active chassis goes to recovery mode, when VSL goes down and dual active is detected. To recover from recovery mode chassis should be reloaded. It will be reloaded automatically, if VSL will be restored. But this is true only if there were no any unsaved config changes in recovery mode. If there were some unsaved changes, chassis should be reloaded manually.
More info is here:
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst6500/ios/15-1SY/config_guide/sup2T/15_1_sy_swcg_2T/virtual_switching_systems.html#29008
