VSS CPU monitoring behaviour
marioderosa2008
Hi all,
Is it normal for VSS cpu useage on 4500-X chassis to be very different in utilisation?
One chassis is very busy and the other chassis is not busy at all in terms of the "show proc cpu history"...
I notice that every 30 mins there is an 80% spike and that the process causing this called "iosd". I take it that this is some scheduled synchronization process maybe?
Is this normal behaviour?
Mario
Rajeev Sharma
Hey Mario,
Regarding your questions:
Is it normal for VSS cpu useage on 4500-X chassis to be very different in utilization? - its normal.
I notice that every 30 mins there is an 80% spike and that the process causing this called "iosd". I take it that this is some scheduled synchronization process maybe? - Indeed
Is this normal behavior? - Yes.
HTH.
RS.
