VSS data path?
anowell
Level 3
Level 3
Simple question...
I'm trying to understand the data path when you have VSS configured.  I have a remote switch that has two connections to a pair of 6500s that are running VSS.  If I was plugged into the remote switch, what connection would I use to get to the the 6500s?  Both?  How is this determined?
THANK YOU VERY MUCH!!!
2 Accepted Solutions
Leo Laohoo
The fastest way to identify which one is active and which one is on hot standby is by looking at the LED light on the supervisor card.  Hot standby unit has the "Status" LED on amber color.
When you console into a standby unit, the prompt is also a give-away.
Jon Marshall
Either connection could be used for traffic to and from devices connected to the remote switch.
With VSS one switch is active and one standby for the control plane but in terms of the forwarding plane both switches can forward the traffic.
Presumably the links from the remote switch are configured as an etherchannel to the VSS pair so it is the etherchannel load balancing method that determines which of the physical links to use.
Jon
Leo Laohoo
Jon Marshall
Jon
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
From remote to the VSS pair the operation is the same as from remote to any other single device, where you have multiple connections, i.e. the remote device "decides" path.
From VSS pair to remote, VSS avoids transiting its VSS mate.  I.e. whether Etherchannel or L3, VSS will use its own link connected to the remote device.  (I.e. VSS doesn't load balance, you load balance to the VSS transit pair and it will maintain the same load balancing.)
