VSS Dual-Active detection
abimadaro4462
Is it possible to configure VSS dual-active detection on the out of band management interface?
Reza Sharifi
For what platform? Also, are you looking at doing fast-hello?
Usually that is not possible because the out-of-band management interface is in a separate VRF.
I'm planning to configure this on 6816-X using fast-hello.
The 6800 uses what is called a "CMP" which not a true out-band-management port. So, I would say no, it will not work.
