VSS ePAgP question
Si
Good Afternoon,
Im just in the process of designing a new core replacement using 4500x in a VSS configuration.
I have about 15/20 port channels to Distribution Cabinets. How many of these should i add into the VSS domain as trusted port channels in the event the VSL fails?
I have a 8gb between the two and the Dist. Cabs have two gb connections, should i look at bonding more channels?
Many thanks
S
Reza Sharifi
You just need one of the portchannels to be part of the ePAGP trusted.
Thanks thats great.
Would it be a good idea to throw more bandwidth at that group?
S
