VSS hardware requirements
I have 2 (WS-C6506-E) and i need to implement VSS,
could you please tell me what is hardware and software requirements for impleminting VSS, and how the connection will be???
Sandeep Choudhary
HI Mohamed,
It depends what you need:
Here is the example of hardware requirement
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/vss.html#wp1053927
Here is VSS deployment procedure:
http://www.cisco.com/en/US/products/ps9336/products_tech_note09186a0080a7c837.shtml
Hope it helps.
Reagrds
