VSS: how to troubleshoot path forwarding ?
gnijs
Level 4
Level 4
In a VSS setup, how can i see if the switch if forwarding across the VSL link for some mac address ?
Example: suppose you have a MEC portchannel 30 with vlan 300 and on this vlan is mac address aaaa.aaaa.aaaa
when you do: show mac-address-table address aaaa.aaaa.aaaa, you will get something like:
Switch1: MAC aaaa.aaaa.aaaa
(*) Active, Vlan 300
Switch2: MAC aaaa.aaaa.aaaa
However, i don't see on which interface the switch is forwarding.
On Switch1, when i disconnect the link in Po30, the "sh mac-address-table" looks still the same:
However, the switch is now forwarding the packets across the VSL. How can i see this ?
didyap
Level 6
Level 6
You can use the command
show mac-address-table {address mac-addr} [all | {interface interface/switch-num//slot/port} | {switch num [module num]} | {vlan vlan-id}]
interface displays Optional) Displays information about a specific interface type; possible valid values are gigabitethernet and tengigabitethernet.
show mac-address-table vlan vlan-id [all | {switch num [module num]}
all displays every instance of the specified MAC address in the forwarding table.
